385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc
Old Aug 1, 2012 | 09:20 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Transmission: 700R4/ Edge 3400
Axle/Gears: 10 bolt/ Richmond 3.73
Decided to part out my '90 GTA combo. Just never did anything with the car. All prices are best offer, no trades. Located in Belleville, IL. 20 min from St. Louis MO. Prefer to sell local but in interested i can ship, just gimme time to find out prices or I can meet up depending on distance. Pics to follow
*385 Stroker (.40" over) 4bolt main vortec truck block. $3800 obo from TB-oil pan, $3300 obo long block.
- Harwood 2" Fibergalss hood. has hood pin holes in front but is currently bolted on. $160 obo
-FAST 4bbl TB, 4150 style mount, 1375 CFM flow, LS1 style TPS, IAC, and GN style regulator. $700 obo for TB intake, and 42's, $600 obo with 30's.
-Holly fuel injection single plain manifold (3-7000 rpm range)
-30lb or 42lb Ford SVO injectors available
-ARP Headbolts and ARP everywhere else.
- PBM Strikeforce(australian make) 200cc runner, 64cc chamber, 2.055” Int, 1.60” valves. Flow advertised as 270 cfm @ .600 amd 171cfm exh. 1.43” springs. Heads are untouched and not ported.
-11:1 compression ratio
-cometic multilayer head gaskets. dont remember thickness but I can find out.
-Comp Cams XE 292XFI. Cam card included and have pic
-1.6 comp cams pro mag rockers and lifters
- Scat 9000 Cast Steel 3.75" Crank
- Eagle I-Beam rods
- Probe .40" over pistons
- Moroso high flow, low volume oil pump
- Stock third gen oil pan
- Uncoated Hooker 2210 Super Comp Lontubes (1 3/4") ($700 for headers and X, $350 obo for headers)
- Custom 3" true duals, x pipe with magnaflo 5" case polished mufflers dumped before axle. Wideband port welded on passenger side. Factory trans cross member was notched to give extra clearance to tuck exhaust up higher. Comes with x pipe.
* stage 2 700R4 from Transmisasions 2 Go in Arnold, MO $1100 obo
-billet servo
-trans go shift kit
- kevlar wideband
-drum saver
- 27 spline input shaft
- 732 pump
-Edge 3400 convertor (can sell seperate) $350 obo
* 3rd gen 10 bolt
- TA girdle cover
- Zexel
- Richmond 3:73 gears (make no noise)
- Alloy USA Steel 28 spline hardened axles
- LS1 Brake calipers ground down to fit a 15" wheel
- Ebay slotted rotors.
* NOS Carburetor style nitrous kit. Large solenoids and x style spray bars. $260 obo
- NOS bottle heater $120 obo
- 10 lb Zex Bottle $100 obo
- NOS progressive controller kit $220 obo
- MSD tach adapter $40 obo
* Moroso line lock $60 obo
Controlled though the factory 730 TPI computer and harness. Idles surprisingly nice with the tune it has. Combo maybe has 500 miles and car was never sprayed and nitrous was never installed. No dyno numbers or track times, but desktop dyno says engine is good for 540HP. Also have various body and interior parts. Just ask. Call or text, 618 979-0998, Josh.
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-015.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-017.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-007.jpg
Old Aug 1, 2012 | 09:23 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Re: 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc
hood pics
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-008.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-009.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-010.jpg
Old Aug 1, 2012 | 09:27 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
more hood
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-011.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-012.jpg
Old Aug 1, 2012 | 09:30 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
specs on cam card
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-013.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-014.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-019.jpg
Old Aug 1, 2012 | 09:33 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
42lb injectors and pics of each rotor
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-018.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-006.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-005.jpg
Old Aug 1, 2012 | 09:35 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
exhaust
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-004.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-002.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-003.jpg
Old Aug 1, 2012 | 09:39 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
rearend and Edelbrock adjustable torque arm. Looking to get $140 obo on the torq arm.
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-031.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-037.jpg
Old Aug 1, 2012 | 09:42 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
nitrous plate and solenoids
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-020.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-021.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-023.jpg
Old Aug 1, 2012 | 09:54 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
line lock, bottle heater, tach adapter
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-025.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-026.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-028.jpg
Old Aug 1, 2012 | 10:02 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
n
Attached Thumbnails 385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-027.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-029.jpg   385 Stroker, 700R4, 3:73 10 bolt, nitrous, etc-gta-pics-030.jpg
Old Aug 1, 2012 | 10:51 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Do you happen to have the brake proportioning valve? How much for the #30 injectors? How big are those slotted rear rotors?
Old Aug 1, 2012 | 11:42 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Yes, $20 for the prop valve, $100 for the 30lb, and the rotors look like they are going With the rear end this wknd.
Old Aug 2, 2012 | 10:29 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
PM being sent.
Old Aug 9, 2012 | 11:58 AM
ylose's Avatar
Want a title? Post!
I like the sound of the intake and FAST. Will have to see if I can sell something.
Old Aug 9, 2012 | 05:18 PM
CradleofFilth08's Avatar
Car: 1992 Camaro Z28
Transmission: 86' 700R4
Axle/Gears: 10 Bolt, 3.42's
How much are you wanting for the true dual exhaust?
Old Aug 9, 2012 | 07:33 PM
88gunmetalgta's Avatar
Interested in the TB alone if you ever split it up.
Old Aug 10, 2012 | 03:09 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Cradle, if this one guy doesn't come by this weekend for the exhaust, I'll do $300 for the true duals.
And 88gunmetal, if this guy coming by this weekend doesn't buy the whole intake and TB i will let you know.
Old Aug 12, 2012 | 11:17 PM
irocZ281986's Avatar
Car: 1986 Camaro Iroc-Z (sold)
Engine: 305 about to be 350
Transmission: full manual 700r4
Axle/Gears: auburn 3.42 limited slip
How much for the entire rear end if you still have it?
Old Aug 13, 2012 | 07:38 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Irocz281986, yes the rearend is still available. I'm asking $550.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
Stangski09
Sep 7, 2015 05:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
