lt1/l98 converted manifold
With fuel rails, use your injectors, dist. throttle body. need remote stat. 350. shipped Ohio. df3755@yahoo.com
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
Re: lt1/l98 converted manifold
300. bare manifold. 450. with fuel rails + remote stat. use your injectors, dist. throttle body. df3755@yahoo.com +shipping ohio
Jd_barrows@yahoo.com
I am very interested
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
25-30 hp. 500-700 rpm top end 89 corvette stock with this manifold, Dave Ohio df3755@yahoo.com
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
So $300 for the intake with the fuel rail? If so, I'm interested in one. Please email me at Aaronrunnells@Gmail.com thanks!
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
wheres the coolant lines come out at? tpi injectors fit? tpi throttle plate also?
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
David,
Quick question, Do you keep these instock? I'm wanting one,but I got to figure out few thing first, with my cars, not your intakes.Thanks.
Car: 1986 Camaro Iroc Z
Engine: 5.7L Corvette L98
Axle/Gears: 2.73 Open
Hey, Do you still have one for sale, I am looking to get a hold of one?
DG
DG
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Are these the only ones you have? Or will you be making more? I am also interested. Will even send u a manifold if necessary. Thanks
If u could please email me your pics of the manifold from all angles, I would appreciate it. BabyJ04@hotmail.com
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
If I sent you an intake what would you charge to just modify it for a distributor? I'm going to be swapping in an LT1 but using the stock L98 computer to run it. So I don't need the extras as far as coolant plumbing or remote t-stat.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Following along.
Can you PM me with some more details of exactly what you are doing? I'd like to know what you are changing. Thanks!
This conversion has been done for years now, all this information is on these forums.
Bump for answer to my question lol
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
