[CA] 4th gen aluminum DS
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
4th gen aluminum DS
Bought this from another member but I upgraded to an S60 rear end so I only was able to use this for about 100 miles. Had no vibrations with this DS. There is a light scratch (cosmetic only) where it rubbed on my driveshaft loop while I was removing the stock rear end.
SOLD
SOLD
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Re: 4th gen aluminum DS
If you don't mind my asking, what brand s60 did you buy and are you happy with it?
Jon
Jon
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
will it slide into a 700R tranny and bolt up to a 9 bolt?
My parents are in San Diego, as in Lemon Grove.
I can maybe have them pick it up, depending on where you are?
Do you have the weight, and the weight savings?
Dennis
Dennis
Car: 89 GTA
Axle/Gears: 4.10
Yeah, it fits any thirdgen with a 700r4 or T5. I can weight it, but it's definitely lighter and causes less vibrations than the stock steel shaft.
I'm about 10min from Lemon Grove. (Clairemont Mesa)
Car: 89 GTA
Axle/Gears: 4.10
I'm parting out a 9 bolt rear end with disc brake mounting brackets also if you need anything from it.
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Happen to have the parking brake return springs from that 9 bolt?
Car: 89 GTA
Axle/Gears: 4.10
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
shipping to 86401?
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
