COMP CAMS custom grind small base circle factory roller SBC camshaft (PRICE LOWERED)
Car: 1991 Firebird
Engine: 383 stroker
My loss is your gain, custom ground small base circle (1.050 base) COMP Cam that literally has LESS THAN ONE MILE on it. After putting the motor and car back together, I had a drivetrain problem so no I'm parting out the whole project. Keep in mind this is for a factory roller block, no a retrofit cam. All of the info you need should be on the cam car shown....it idled pretty good on my TPI 383 by the way. Also, make sure that you realize that the lift numbers reflect a 1.6 ratio rocker and not a 1.5 as I'm used to seeing on most cam cards. If you're planning on running a 1.5 rocker, simply multiply the lobe lift (towards bottom of card) by 1.5 and that will give you your lift. This cam is $296.95 brand new from Summit or Comp. Please feel free to PM me if you have any questions. First $125 shipped to the lower 48 takes it.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: COMP CAMS custom grind small base circle factory roller SBC camshaft (PRICE LOWER
PM sent
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 1992 Camaro Z28
Transmission: 86' 700R4
Axle/Gears: 10 Bolt, 3.42's
It got here today. Came home for lunch and met the mailman. Thanks a lot man, this is going to make my 350 VERY happy!
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Bump
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm confused..
Engine: LS3
Me too. The cam is still in my basement...
Cradle, you must have this thread confused with some other one.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Engine: LS3
Oh, my mistake. I posted my bump in the wrong thread. I had my cam for sale thread window open on an adjacent screen.
Sorry about that.
Sorry about that.
1988iroc350tpi
Aug 14, 2015 07:52 PM
