9 second 383 lt1, 4l60e, tuned computer......
Old Mar 7, 2013 | 06:18 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I have a 383 95 lt1 for sale
-Forged eagle rotating assembly
-H beam rods
-Coated Mahle pistons, 12.5:1 compression
-Manton push rods
-Morel solid roller lifters
-TD shaft mount 1.6 rockers
-4 bolt mains
-Milodon oil pump with hardened shaft
-CNC 21 degree trickflow twisted wedge heads done by airflow inductions
-ported intake by airflow inductions
-Monoblade throttle body
-36lb svo injectors
-Modified fuel rail for -8 in, -6 out
-electric water pump
-7 qt oil pan
-hooker long tube headers
-solid engine mounts
-msd optispark
-msd 8.5mm wires, with heat boot ends
-all sensors
-dyno tuned computer
-stand alone engine harness
-pro built, pro street elite 4l60e tranny
-Rossler tranny brake
-Rossler black box for full manual shifting
-edge 4000 stall converter, lock up delete to reduce weight
-nx direct port nitrous with jets from 50-300 shot
-powerMaster high torque mini starter
-ati balancer
-I'm sure I'm am forgetting a lot to
I have all receipts, dyno charts, and time slips to prove everything. The engine has 3 passes on it since it was freshened and the tranny is fresh with no passes since freshening up last month. Engine and tranny have never been hurt!
This is a 9 second combination (in street trim) ready to go in any f body, drag car, or hot rod. I am in Pittsburgh pa and if interested pm me a serious offer.
Old Mar 7, 2013 | 06:27 PM
Car: 1987 firebird
Transmission: 4l60e
Re: 9 second 383 lt1, 4l60e, tuned computer......
No I will not part out, so please no pm's asking.
Old Mar 9, 2013 | 03:27 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
price?
Old Mar 9, 2013 | 05:48 PM
Car: 1987 firebird
Transmission: 4l60e
Make me an Offer if interested.
Old Mar 9, 2013 | 05:51 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
Forum rules require a price...
Old Mar 9, 2013 | 05:55 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Nice build I'll be keeping an eye on this one to see what it goes for.
good luck with the sale.
Im trying to get rid of a turbocharged 383 lt1 setup (see sig) for a fraction of the build cost. Not alot of buyers out there right now.
Old Mar 9, 2013 | 06:14 PM
Car: 1987 firebird
Transmission: 4l60e
$7500.00 takes it all
I have over $5000.00 in the heads alone (top of the line everything) and over $2500.00 in the engine/tranny recient freshening. It has a custom grind camshaft and makes power to 6900rpm. I will even through in a precision performance 4l60e shifter.
I have a lot of time and money in this build and the only reason I'm looking to sell is I am now building a full tube chassis car.
Like earlier stated I can provide all receipts and paperwork. I will even tear it down for inspection if wanted.
Old Mar 9, 2013 | 09:47 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
what cam is in it?
Old Mar 11, 2013 | 11:18 AM
Car: 1987 firebird
Transmission: 4l60e
It is a custom grind matched to the heads. 680's lift 280's duration, I would shift at 6800/6900.
L0tuS
Oct 4, 2015 08:07 AM
New2Chevy
Sep 28, 2015 12:35 AM
L0tuS
Sep 4, 2015 11:16 PM
IROCZ1989
Sep 4, 2015 11:54 AM
