COMPLETE C5 Z06 front brake kit. NEW!!!! SOLD
Transmission: A4
SOLD
I have a complete C5 Z06 front brake kit for sale. Everything is new and it has all be powder coated. This is everything you will need to install a big brake kit on the front of your 3rd gen. Kit includes the following:
2 C5 Z06 calipers
2 GM drilled rotors
2 abutment brackets
2 adapter plates
GM front brake pad kit
[/B]
2 modified spindles powder coated black will include hubs
2 modified hubs powder coated black with new Timken bearings and seals.
2 Earls stainless brake lines
Complete hardware kit which was bought new from GM.
I may have missed something but I dont think so. What you see in the pics if what you get. Shipping most likely will be high but I can get detailed quotes for those of you on the West coast. All these parts were bought new last December. Asking $950 or you can pick it up in Westport Mass. You cant build this kit for under $1,100 AND have all the parts powder coated on top of it!!!
I also have 2" spacers for sale if you need them.
2 C5 Z06 calipers
2 GM drilled rotors
2 abutment brackets
2 adapter plates
[/B]
Transmission: A4
Re: COMPLETE C5 Z06 front brake kit. NEW!!!!
I'm not splitting up the package like that unless someone else commits to buying the rest
As for them fitting an 84, I am not 100% sure but I can't see why not.
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Transmission: A4
They require at least 17" wheels to them to fit. I think I remember reading here that you can grind some material off the calipers.
Transmission: A4
Lowered price. Shoot me your best offer guys, the worse I can say is no.
Car: 91 Z28
Engine: worked crate 350
Axle/Gears: Z posi
DROOOL....
I have 16" wheels that hit the calipers. These are amazing
I need some better than stock calipers as my left side sticks. I could just rebuild the stockers but why do that if I can upgrade
Transmission: A4
You can either buy the 1LE kit and use the 16" wheels you already have or just replace the calipers with new or reman ones from the local parts store. They are cheap there and most offer a lifetime warranty. If you go that route then I highly suggest replacing both sides at once and replacing the rubber hoses.
I could have swore that some guys were able to fit the Z06 brake kit inside a 16" wheel IF they grinded down the cooling fins on the calipers. I could be wrong though
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
The LS1 camaros brakes fit under the 16s, and the C5 vette will fit 17s without modification. The C5s will fit under SOME (not all) 16s if you grind the outer fins off the top (make them look like the LS1 Camaro calipers)
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
*post removed*
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Are the discs 12" or 13" with this setup?
Thanks,
Jon
Thanks,
Jon
Transmission: A4
Car: 1992 Chevy Z28 - Black
Engine: ZZ4 350 HSR w/ 100 shot
Transmission: Automatic - Hurst dual gate
Axle/Gears: Moser 12 bolt 3.42 Eaton gears
I'm very interested see my PM
Car: '83 Berlinetta
Engine: 383 CI
Pm sent on calipers, abuttments, brackets and lines.
Jon
Jon
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
i sent a pm.. im searchin for a whole kit for a quick install, no pieces.
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
How much is this kit new complete? I might be interested and I can local pickup.
Transmission: A4
Hubs, spindles, brackets, bearings, hardware, and wheel studs were $400
lines were $100
powder coating was $300
I have $1550 in this kit. it is a simple bolt in, bleed your brakes and go kit. The parts will not rot out either because of the coating. You cant go wrong for $950
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
i will take the hub and spindle also the lines if they would work on a 5th gen brake swap this is exactly what ive being looking for
Transmission: A4
TTT. Guys Im willing to entertain reasonable offfers on the entire package. I really dont want to break this up unless I can get solid responses from members who want all of the parts. I dont want to sell just one or two parts out of it and then be stuck with the rest.
Transmission: A4
Transmission: A4
Transmission: A4
Im willing to take $900 shipped for the entire setup. I need to move these things ASAP.
Transmission: A4
Yes I still have the kit. Pm me and we can discuss it. Let me know your location.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Willing to seperate? If so, I'd be interested in adapter plate and hardware, caliper carrier/abutment bracket, and ss brake lines
Transmission: A4
Re: COMPLETE C5 Z06 front brake kit. NEW!!!! SOLD
Yes, I do still have the Skulte 2" spacers. Its just the two fronts that I have. $85 shipped. paypal ID is bottledz28@aol.com
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
KO1
16
Oct 15, 2015 05:00 PM
dbrochard
Sep 19, 2015 08:13 PM
blackandblue02
Sep 10, 2015 08:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
