Parting out 5.7 TPI Firebird Formula 89
Old Apr 24, 2013 | 12:05 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Let me know your needs beyond this list.
-Wiring harness- $125 shipped
-ECM with superchip- $100 shipped
-TPI complete set up(intake, plenum, runners, distributor) - $300 shipped
- dual fans- great working condition- $ 75 shipped
- MAF sensor and 2 rubber boots w K&N air cleaner- $100 shipped
Old Apr 24, 2013 | 05:29 PM
Re: Parting out 5.7 TPI Firebird Formula 89
Starting an album with pics of the parts....
http://s1140.photobucket.com/user/sl...engine%20items
Old Apr 25, 2013 | 04:07 PM
Formula383's Avatar
Car: 88 Firebird Formula
What color is the interior
Old Apr 26, 2013 | 11:40 AM
Interior is black.
Old Apr 26, 2013 | 12:44 PM
3GEN90's Avatar
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
How much for the top part of the a/c box that houses the evaporator?
Old Apr 26, 2013 | 07:19 PM
Let me check to make sure there's no damage, and I'll get back to you.
Old May 28, 2013 | 07:01 PM
xstang77's Avatar
do u have swaybars?
Old May 28, 2013 | 07:10 PM
Originally Posted by xstang77
do u have swaybars?
Let me see if they are in good condition.
Old May 30, 2013 | 07:46 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Do you have
TPI Throttle Cable
Aluminum Distributor Cover
Stock Rubber Motor Mounts (To put poly mounts into)((Only interested if you would have one of the other items and very cheap)
Old May 30, 2013 | 08:50 PM
hotrodder355's Avatar
Car: 1991 RS Convertible
Engine: 377 w/Holley Commander 950 EFI
Axle/Gears: 2.73:1 with Auburn Posi
Is that for just the 2 fans or for everything including the upper and lower plastic mounting brackets?
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
I need the headlight control module. Headlight surrounds and the front blinkers that go to the inside of the headlights.
Old Jun 4, 2013 | 09:47 AM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
I may be interested in the MAF and air filter. Can't see the pics, can you pm me pics? - thanks.
Old Jun 5, 2013 | 07:48 AM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
I need a fuse panel cover.
Old Jun 5, 2013 | 04:33 PM
Mpperry001's Avatar
Car: 1983 Daytona 500 Edition Trans Am
Engine: Carb 305
Transmission: NWC T5
how much for just the MAF?
Old Jun 6, 2013 | 10:14 AM
Topspeed's Avatar
Car: '84 Firebird
Transmission: 700r4 with kit
Axle/Gears: BW 3.73 Posi
Do you have the collant overflow reservoir and what would you ask for it?
Old Jun 6, 2013 | 07:48 PM
Originally Posted by 91phoenix
Do you have
TPI Throttle Cable
Got the throttle cable. Don't have aluminum cover, only plastic one. Do have mounts, but they are old.
Sold them already.
I have the headlight surrounds and I have the control module. I don't have the blinkers, though.
I do have the mass air flow sensor, and still have the K&N air filter. Will try to PM pics.
Don't have the cover- sold.
Make me what you feel is a reasonable offer.
I do have the coolant bottle- make me an offer.
Old Jun 7, 2013 | 09:25 AM
396lsx's Avatar
Engine: 350 tpi
How much for the headlight surrounds and control module
Old Jun 7, 2013 | 09:51 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
posi rear?
Old Jun 7, 2013 | 03:44 PM
Originally Posted by Imadude_134
posi rear?
It is a posi disc brake rear the Australian 9 bolt one. 3.27 gears.
Old Jun 7, 2013 | 05:24 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
ok, forgot that 89 used 9-bolt. looking for a 10 bolt. Thanks for the reply!
Old Jun 8, 2013 | 07:29 AM
I do have a posi 10 bolt rear out of an 88 Camaro.
Old Jun 30, 2013 | 11:34 AM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Still have the MAF sensor?
Old Jul 2, 2013 | 10:06 AM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
How much were you looking for the rear, preferably the 9 bolt? And where in PA are you?
Old Jul 2, 2013 | 10:44 AM
Royal_Z's Avatar
How much for the sun visors? Pics?
Old Jul 3, 2013 | 05:50 PM
Sold already
Sold as well.
Old Jul 3, 2013 | 05:59 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
The MAF sensor???
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
Randomtask2
Aug 13, 2015 01:57 AM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
