[NC] 91 Camaro RS Engine Partout
Old May 31, 2013 | 08:25 AM
bonylad's Avatar
Car: 09 Honda Fit / 91 Camaro RS
Post up what you need and I will PM you. We can discuss price and shipping.
Pretty much anything under the hood, except transmission. PCM - Harness - U tell me.
Need cash to fund the 283 carb swap, and wont need this crap (not crap but useless to me.......some clarification for you).
Motor ran but has sat - has 80K. Its a stock 305 L03 with a TurboCity TBI unit - Hypertech chip - stock other than that. Post up!
Old Jun 1, 2013 | 06:29 PM
bonylad's Avatar
Re: 91 Camaro RS Engine Partout
Updated with some items.
Distributor (has a replacement ignitor in it....needs new cap and rotor button)
Ignition coil
Map sensor with bracket
I dont know what this is
Washer Reservoir tank (no leaks and no pump)
Under hood courtesy light
2013-06-01185007_zpse1c7bf52.jpg?t=1370128871
Make offer on parts.....I dont know what this stuff is worth really. So Im going to look some things up.......but I dont need this stuff.....so offer up!
Old Jun 1, 2013 | 07:01 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
how much for a set of spindles?
Old Jun 2, 2013 | 07:39 AM
bonylad's Avatar
Not for sale, Im really referring to driveline parts excluding trans and diff. I need that stuff for the swap. I apologize if my ad wasnt clear.
Old Jun 2, 2013 | 03:33 PM
therobot's Avatar
Car: 1991 Camaro RS
How much do you want for the two metal fuel lines from the throttle body to where they connect to the rubber lines?
Old Jun 3, 2013 | 07:06 AM
bonylad's Avatar
Pmed.
Old Jun 5, 2013 | 06:58 AM
bonylad's Avatar
Pulled a stock A/C Compressor, and alternator today.
Old Jun 5, 2013 | 08:09 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
How much for the map sensor? I just want a back up one lol
Posted from Thirdgen.org App for Android
Old Jun 6, 2013 | 07:14 AM
bonylad's Avatar
Pmed.
Old Jun 6, 2013 | 07:17 AM
bonylad's Avatar
Pulled the a/c and smog pump bracket (with smog pump)
Also have a set of March Underdrive pulleys.......have to strip them off crank - alt - and water pump.
Old Jun 10, 2013 | 09:33 AM
bonylad's Avatar
I pmed you sir, no reply. Make offer?
Old Jun 10, 2013 | 09:35 AM
bonylad's Avatar
And the pulleys are off. They are the March Underdrive "power and amp" series - three pulley set (water pump, crank, and alternator with cover).
Guys this stuff is going cheap so make an offer.
Old Jun 11, 2013 | 07:40 AM
bonylad's Avatar
Also pulled a ECM/PCM with a hypertech chip.
Old Jun 11, 2013 | 07:42 PM
daddyd87mcss's Avatar
Want a title? Post!
hello, I am looking for a complete serpentine accessory kit setup if you still have all parts and bolts for my 87 monte SS.
Old Jun 12, 2013 | 07:59 AM
bonylad's Avatar
I will pm you
Old Jun 21, 2013 | 07:30 AM
bonylad's Avatar
Bump.....cheap!
Old Jun 21, 2013 | 08:46 PM
Pistol Pete's Avatar
Car: 87 Z-28
Transmission: Automatic 200 Metric Turbo
Axle/Gears: Strange Axles & 5.14 Gears
I need undented TPI runners for the plenum.
Old Jun 22, 2013 | 07:44 AM
bonylad's Avatar
TBI sir.
Old Jun 22, 2013 | 08:00 AM
Car: 87 Z-28
I have a tuned port inj. 305.
Whats the difference with TBI & TPI ????
Old Jun 22, 2013 | 08:33 AM
Car: 87 Z-28
OK now i know the difference, i googled both of them.
Old Jun 24, 2013 | 12:49 PM
bonylad's Avatar
Sold some fuel lines, pulleys, and the TBI unit. Still have some parts. Post up and ask for what you need and I will do what I can!
I have the PCM with a Hypertech chip with PCM holder. Make offer.
Old Jun 28, 2013 | 05:15 PM
Pat Hall's Avatar
Btw, the part in pic#3 is an ESC (Electronic Spark Control) module.
Old Jul 6, 2013 | 02:36 AM
Alessandra's Avatar
Is the MAP system sold yet?
Old Jul 7, 2013 | 08:20 AM
bonylad's Avatar
no its still available. make offer?
Old Jul 8, 2013 | 10:25 AM
Alessandra's Avatar
I have the wiring I'm actually just looking for the 730 ECM and the knock sensor. $100 for both, shipped?
Old Jul 8, 2013 | 10:47 AM
Alessandra's Avatar
I'm not sure it'll fit. Sorry I'm new to this stuff.
Old Jul 8, 2013 | 07:48 PM
bonylad's Avatar
Pmed you. You asked about the MAP and then the knock? Please reply to your PM so I can get it straight what you would like. Thank you!
Old Jul 8, 2013 | 08:50 PM
Pat Hall's Avatar
Just a FYI. I'm about 99% sure the knock sensor off a TBI car is different from a TPI car with the '730 ECM. In fact, the TBI ECM's are wayyy primitive compared to the '730! The actual MAP sensor should be the same though.
Old Jul 9, 2013 | 07:15 AM
bonylad's Avatar
Thanks for the clarification! If I have parts the OP wants I will sell them, but would be nice for that OP to know if it will work lol......
Old Jul 9, 2013 | 06:36 PM
Pat Hall's Avatar
Yeah, no problem, glad to help. Just to be sure, I went to Autozone's website and checked the parts for both a SD TPI Camaro and a TBI Camaro. The MAP sensors are both the same part#, but the knock sensors are a different part# for each.
Old Jul 10, 2013 | 07:15 AM
bonylad's Avatar
BUMP
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
