[Sold] Corvette L98 aluminum cylinder heads. TPI 10088113 58cc 93k miles just removed
Old 08-18-2013, 08:34 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I just bought a complete L98 long block from a 1988 corvette. Corvette was totaled from behind last month. I just removed a nice set of super light weight 58cc cylinder heads that I am not gonna use.
Here are the specs I got from the net
Casting: 10088113
Material: Aluminum
Intake Runner Volume (cc): 163
Combustion Chamber Volume: 58
Valve Diameter: I: 1.94" E: 1.50" D" port exhaust
Screw in Rocker Studs
Pushrod Guide Plates
Need to get $450 shipped
Please feel free to ask any questions.
FIRECHICKEN is offline
Old 08-19-2013, 08:20 PM
83 Crossfire TA's Avatar
Re: Corvette L98 aluminum cylinder heads. TPI 10088113 58cc 93k miles just removed
Any idea if it smoked starting up or had any other issues? Are all the threads good?
83 Crossfire TA is offline
Old 08-19-2013, 08:27 PM
Not 100% sure. It was a friends Corvette, but I have not seen it for awile. I was thinkin of lapping the valves and putting on some new seals but then I would probably need to get $500 for them.
Old 08-20-2013, 09:25 PM
MinnGreenGT's Avatar
Car: 1987 Pontiac Fiero GT
Engine: L98/TPI (in progress)
Transmission: 4T60
Hmmm.... peaking my interest.
Would you happen to know if these simply bolt on to an otherwise-stock '89 Firebird Formula 350? (I'm beginning to dig into my first engine build, and trying to decided when & where to spend money on it).
MinnGreenGT is offline
Old 08-21-2013, 01:45 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Do the vette valve covers come with them? I need the valve covers as much as the heads.
abray1 is offline
Old 08-21-2013, 04:53 AM
These heads will bolt right up to your engine. Only differences are increased horsepower, higher compression ratio, no egr.
I you want to retain an egr you need a corvette intake manifold which I also have.
I have the corvette magnesium valve covers as well but they are not included in this price.
Old 08-29-2013, 08:36 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
I know these are sold, but these made me think.
I've always liked the look of the magnesium valve covers from the Corvette TPI motors... depending on price, would these be a decent upgrade for my 305 TPI? Other than some weight savings.... I assume the flow has got to be slightly better than the iron units on my motor now.....
IROCgiraffe is offline
Old 08-29-2013, 08:42 PM
You can put magnesium valve covers on any center bolt head like your 305 has.
Yes the aluminum L98 350 head will be a good improvement from stock. They would increase your compression and allow you to run more timing. This alone would increase horse power. They should flow better than stock 395 heads, I believe the valves are bigger but not 100% sure. I can also tell you they are about a third the weight of an iron head.
Old 08-29-2013, 08:48 PM
Engine: LB9 | LS1
Thank You for your response. This sounds like a budget friendly, OE part upgrade I have been looking for
1992rs/ss
05-19-2020 07:02 PM
Vintageracer
01-10-2020 05:33 PM
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: [Sold] Corvette L98 aluminum cylinder heads. TPI 10088113 58cc 93k miles just removed
