[GA] 700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts
Old Aug 22, 2013 | 02:48 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
305 TPI setup, 9 Bolt Borg Warner, Fuel Tank, misc parts
Pictures can be seen here of everything I'm selling. https://www.dropbox.com/sh/8mcu0ql6o...ac10Af5NbtGmea
- 9 bolt Borg Warner posi rearend with disc brakes/calipers 2.77 gear. - $200 OBO. Local pick up only.
- TPI fuel injection from an 86 305 - $150
- 89 TPI 5.7 engine wiring harness - $150
- 89 TPI 5.7 ECM computer - $100
- Metal fuel tank with brand new fuel pump installed. - $100 Local pick up only.
- Felpro Intake Manifold Gasket Set for 85-92 305/350 TPI Brand New unopened. Part # MS 93035-1 - $30 Shipped
- Have another partial Felpro gasket set. Missing Intake manifold gasket, rtv and 1 injector o-ring - $15 Shipped
- MAF descreened - $75
- Distributor - $60
- ACCEL Extreme 9000 Ceramic Spark Plug 8mm Wire Set $75
- Carter fuel pump - $20
- Tpiparts chip - $40 Shipped (setup for 42lb injectors, NO-VATS, NO-EGR, NO-coldstart and NO-AIR ) Plugs in between Prom and ECM.
- Stock steel drive shaft - $60
- Energy Suspension torque arm mount bushing New - $15
- Chrome Timing Chain cover part #4590 New - $15
- LT1 Intake - $50
- Red Leather rear seats - $50 - Local pick up only
- Red seat belts. Minus front receivers - $75
- Auto shifter - $25
- Auto leather **** - $10
Car stereo:
- 600.1 amp 06-07 model - $120
- 350.2 amp missing a side cover - $70
- Rockford Fosgate .5 farad capacitor - $50
- 12" Alpine type R sub in a ported box - $100
More pics can be seen here of everything I'm selling. https://www.dropbox.com/sh/8mcu0ql6o...ac10Af5NbtGmea
Old Aug 24, 2013 | 01:18 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Re: 58mm TB, 30lb Injectors, 350 TPI + 700R4, misc
More Pics. Bump.
Attached Thumbnails 700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-08-27-08.15.56   700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-dscn0833-copy.jpg
Old Aug 25, 2013 | 05:03 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Added
LT1 Intake - make offer
700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-08-25-16.13.36
Old Aug 28, 2013 | 07:09 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Re: 58mm + 52mm TB, 30lb Inj, 350 TPI + 700R4, misc
Bump
Old Aug 28, 2013 | 10:48 AM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Whats the lowest on injectors? Do they work how many miles on them?
Old Aug 28, 2013 | 06:57 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Yes they work. They have about 3k miles on them. Sent PM to you about price.
Old Sep 2, 2013 | 09:32 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Parts added:
Energy Suspension torque arm mount bushing New - $20 Shipped
Chrome Timing Chain cover part #4590 New - $20 Shipped
Attached Thumbnails 700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-08-27-08.13.04.jpg   700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-08-27-08.13.27.jpg   700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-08-25-16.14.05.jpg
Old Sep 8, 2013 | 10:16 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
bump
Old Sep 8, 2013 | 10:52 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
is the 52 mm TB for LT1 or TPI?
Old Sep 8, 2013 | 11:27 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Should work with TPI. It might also work with LT1.
Old Sep 8, 2013 | 01:24 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
do you mind doing a tps side and back shot? do you have a PN for that tb?
Old Sep 8, 2013 | 06:11 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
The 52mm TB part # is 17086051 it should be a direct bolt on for 85-88. Could use on a newer one with a throttle cable swap. I'll post pics in a little bit.
Old Sep 8, 2013 | 07:07 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Here is a pics of the throttle hook up and tps side.
Attached Thumbnails 700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-09-08-20.02.55.jpg   700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-09-08-17.37.34   700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-09-08-17.37.47
Old Sep 16, 2013 | 09:47 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Bump
Old Sep 17, 2013 | 02:58 AM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Part number on fuel pump?
Old Sep 18, 2013 | 01:35 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Part #07E25A
Old Sep 18, 2013 | 05:38 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
That doesn't seem to be right, no info. on it on their site or anywhere else.
Old Sep 18, 2013 | 10:38 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Yes I know I looked and couldn't find it either. The number 994 is also on it. Here is a pic.
Attached Thumbnails 700R4, 9 Bolt Borg Warner, Fuel Tank, misc parts-2013-09-18-02.13.58.jpg
Old Sep 23, 2013 | 03:22 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Price drop on a few items.
Old Sep 24, 2013 | 05:22 AM
TPIcruiser's Avatar
Want a title? Post!
Do you still have the Holley TB?
Old Sep 24, 2013 | 08:19 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Yes I still have it. Can have shipped tomorrow if I receive payment today.
Old Oct 6, 2013 | 04:52 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
58 MM Holley TB - SOLD
450.4 Amp - SOLD
Old Oct 19, 2013 | 07:42 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Bump
Old Oct 27, 2013 | 12:22 AM
Juan_Garza's Avatar
Car: 91 Firebird convertible
Engine: 350 tpi
Transmission: 700 r4
Axle/Gears: 3.73's
Still got the tpis throttle?
Old Oct 27, 2013 | 02:20 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Old Oct 27, 2013 | 08:25 PM
Juan_Garza's Avatar
Engine: 350 tpi
Axle/Gears: 3.73's
how much shipped to 78516? message me
Old Nov 6, 2013 | 12:58 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Added some parts.
Old Nov 28, 2013 | 03:08 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Re: 52mm TB, 30lb Inj, 350 TPI + 700R4, misc
Bump.
Old Jan 17, 2014 | 09:54 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Bump.
Old Jan 19, 2014 | 09:21 PM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
how many miles are on the heads if you're willing to separate? one of mine is trashed.
Old Jan 19, 2014 | 10:16 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
I'll take the wire loom if still available?
Old Jan 20, 2014 | 11:38 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Yes, I still have the wire loom.
Old Jan 20, 2014 | 01:49 PM
Benc1's Avatar
What's shipping to 23970 gonna run me?
Old Mar 9, 2014 | 08:36 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Bump.
Old Apr 22, 2014 | 08:26 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Bump.
Old May 29, 2014 | 06:39 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Do you still have the injectors, and what year engines are the PROM chips for?
Old May 29, 2014 | 07:34 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Yes I still have the injectors. The prom is for 89.
Old Jun 28, 2014 | 09:34 AM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Added and updated a few items.
Old Jun 28, 2014 | 03:34 PM
cheesehomer's Avatar
Car: 1987 Iroc Vert
Transmission: 5 spd
Is that a in line fuel pump or in the tank ?. Is it also High volume ?.
Old Jun 28, 2014 | 06:01 PM
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
In the tank stock replacement fuel pump.
Old Jun 30, 2014 | 10:27 AM
Pics of the headers?
Old Jul 2, 2014 | 01:26 PM
  #42
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
I tried to upload some pics from my phone but it's not letting me. Follow the link below should be pics of everything I'm selling.
Old Jul 3, 2014 | 12:06 PM
  #43
Ok found thanks, do you have the y-pipe too?
Old Jul 4, 2014 | 04:33 AM
  #44
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
No I do not have a y - pipe for it.
Old Jul 15, 2014 | 07:11 PM
  #45
MerchantMariner's Avatar
Want a title? Post!
Car: 1987 Trans Am GTA
Engine: 5.7 TPI 350... for now
If no one has bought the 52mm TB off you already, PM me. Assuming free moving, in good working condition?
Old Jul 15, 2014 | 07:44 PM
  #46
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Re: 350 TPI/700R4, 30lb Inj, Headers, misc
52mm TB already sold.
Old Jul 23, 2014 | 09:42 PM
  #47
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
do you still have the injectors ?
Old Jul 24, 2014 | 12:35 AM
  #48
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Yes still have the injectors.
Old Jul 24, 2014 | 09:57 PM
  #49
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Injectors are sold.
Old Jul 26, 2014 | 02:53 PM
  #50
ezip's Avatar
Car: 89 IROC-Z
Axle/Gears: 4.10
Headers and Engine are sold. Willing to part with rearend, fuel tank, wiring harness and a lot more stuff now. Added MAF, Distributor, ACCEL 8mm Wires. Will be adding more parts to the list later today.
