[VA] probe 383 pistons 30 over brand new p3831f-030
Car: 91 t/a gta
Engine: 383
Transmission: t-56
Axle/Gears: moser/auburn/410
I have a set of brand new 30 over probe forged fps pistons. I bought them but they are for a press fit 5.7 inch rod and I need a set for a floating rod. Asking $225 or make an offer. Summit sells them for $365
Car: 91 t/a gta
Engine: 383
Transmission: t-56
Re: probe 383 pistons 30 over brand new p3831f-030
still available. $260 shipped, who wants them?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Only problem is Probe show that part # as having 2 valve reliefs and yours have 4 ?
http://www.probeindustries.com/Chevy...s_p/p3831f.htm
http://www.summitracing.com/int/part...-030/overview/
Also state that they have Spiral locks so you can use then for pressed or floating pins
so maybe what you have is not what is written on the box?
Any part # on the pistons themselves?
The correct ones can be had for $270
http://www.flatlanderracing.com/probe-factorychevy.html
Car: 82 Z28
Transmission: T400
Actually if you look at the listings Probe don't make any 383 pistons with 4 valve reliefs
http://www.summitracing.com/int/sear...rder=Ascending
http://www.probeindustries.com/Chevy...how=100&page=1
Car: 91 t/a gta
Engine: 383
Transmission: t-56
Im not sure, the part number is correct on the pistons. All the webaite I look at say press or float depending on application. As for the 4 reliefs, I have no idea. Ill call probe and see if I can get some info. Maybe they are old style probes or something. Ill get back with yall with what they say
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
any one ever hear of fly cutting pistons?
Car: 82 Z28
Transmission: T400
I'm interested , just need to know the cc with the 4 reliefs so I can calc if they will work with the heads I already have ready to use on my next 383 build.
The CR may be too too low
Car: 91 t/a gta
Engine: 383
Transmission: t-56
I called probe today. They are correct. They switched 4 relief to 2 relief and to press and floating style 3-4 years ago. I now realize that the box has 2005 on it. If anyone has any questions feel free to call probe 310-784-2977. Vetteoz ill see if I can find that out for on them
Car: 91 t/a gta
Engine: 383
Transmission: t-56
This is in the book with the pistons. Looks like 4 cc valve reliefs
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
man I need these but not a good time of year for it here is a bump and maybe early next year.
dbrochard
09-19-2015 08:13 PM
UltRoadWarrior9
09-02-2015 08:24 PM
