INTAKE MANIFOLD - Sold
Re: Custom SBC EFI Tunnel Ram INTAKE MANIFOLD!
Below are photos of Moroso part numbers 63425 and 63426 remote thermostat housings. I recommend using one of these. Run the two included hoses, from the rear coolant fittings, into the remote thermostat housing. Then connect your water neck and upper radiator hose to the remote housing. The rear manifold connection hoses can either be run to the drivers side, or run up underneath the plenum & runners, & out under the throttle body.
Car: 87 GTA
Axle/Gears: 3.42 posi
Did you ever run this intake? Any numbers or what was the complete setup? Thanks
No, I have installed it on an engine, but never ran the engine. I did pressure test the coolant system on the engine though, so I know that the manifold seals well with the provided gaskets.
Car: 87 GTA
I'm curious as to why spend spend all the money and time on this intake and never really run it? What's the reason for selling?
Well, I really would like to get this sold. Due to the lack of action here, I'll have to put it on that big auction site tonight. Everyone here is more than welcome to bid on it. I'll list it as "custom efi tunnel ram" and I'll start it real low, and you can put in whatever it is worth to you.
im willing to throw a few bids at it , just curious as to if it would match up well with a dart pro 1 platnium intake port , this is a rasied runner head , which requires a raised runner or vortec intake
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
Saw it sold for 490$ on flebay...Really cheap for someone Who needed it!
i didnt catch this till 2 hours before the end of auction ( so its my fault for not getting a reply from him intime ) but i was going to throw a bid on it , didnt wanna take the chance of not knowing if the ports would line up with my new heads though
i didnt win it , not sure if who did is from tgo or not
ambainb
Apr 25, 2016 09:21 PM
The billet hold down block is securely held down with two big flat head screws from the under side of the manifold.
