[Sold] LS1 Brake upgrade brackets
Old Jan 13, 2014 | 03:39 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
Would anyone be interested in buying these? I made 2 sets of the brackets when I did the my brake upgrade and just found them while cleaning up my garage. Asking $50, free shipping or make offer.
Attached Thumbnails LS1 Brake upgrade brackets-img_0387.jpg   LS1 Brake upgrade brackets-img_0388.jpg   LS1 Brake upgrade brackets-img_0389.jpg
Old Jan 13, 2014 | 05:03 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Re: LS1 Brake upgrade brackets
Thickness of material. And specs it was made to?
Old Jan 13, 2014 | 05:41 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
They are of 5/16" steel. And the pic of the template I used. I'm still looking for the source of that template. I know it must be in my notes somewhere. Also, I'm not sure what " 3/8" steel ? " or other notes on the template page are for, it's been a while.
Old Jan 13, 2014 | 05:52 PM
Benc1's Avatar
Last question. What size holes drilled. I want to tap the lower hole. Need to make sure there is still enough material left.
Old Jan 13, 2014 | 06:25 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
I'm very confident that I drilled .500" holes to accomodate M12 bolts that I used to bolt the bracket to the spindle. The caliper carrier bolt holes appear to be a little bit smaller, not much, can't remember why. I wish I still had my dial calipers.
I can email you a few word documents that I used as guide. I collected allot of info before I even started the project.
Another note - I didn't have to use spacers anywhere, the caliper perfectly aligned with the rotor.
Old Jan 13, 2014 | 06:27 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
Also, I just noticed that I started this project 10 years ago come July.
Old Jan 13, 2014 | 10:36 PM
Benc1's Avatar
Can you remember back to when you did this mod. Did the bottom bolt head hit the caliper?
Old Jan 13, 2014 | 11:09 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
No, not the bolt head but the bracket itself. That's the reason for the indentions in the bracket, indicated by the arrows in the pic. Of course you should check the clearance on installation. You may have to do a little grinding on the bracket and the spindle, I did.
BE SURE to wear safely goggles when grinding. Maybe some day I'll tell you about my trip the eye doctor.
Old Jan 13, 2014 | 11:38 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
how much? pm me
Old Jan 15, 2014 | 09:14 AM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
bump
deracer
Apr 11, 2016 12:04 AM
Genopsyde
Nov 11, 2015 10:46 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
