[TX] 93 M29 T56---freshly rebuilt by Texas Drivetrain Performance
Old 03-13-2014, 12:52 AM
HotRodV6's Avatar
Car: 93 S10 RCSB
Engine: Corvette LT1
Transmission: 93 M29 T56
Axle/Gears: 8 3/4
I have a 93 M29 Close Ratio T56, it has the same gear ratios as the 2001-2004 ZO6 corvettes. It has been freshly rebuilt to stage 2 specs by Texas Drivetrain Performance in Ft. Worth. It has the bell housing, clutch fork and pivot, & the slave cylinder spacer. I also have a lightly used B&M Ripper shifter with a B&M Hammer T-Handle, a new bronze shifter bushing, and a new stock replacement clutch kit that goes with the trans, and a stock replacement flywheel.
This trans does not have the skip shift solenoid, it was removed from a 93 trans am and was stuck in third gear when i bought it, i thought it was a busted shift fork, but it turned out that one of the synchronizer keys came loose on third gear causing it to be locked in gear. everything else in the trans was very clean, only some slight wear on the main shaft, which TDP welded up the shaft and machined it back down so that the gear/bearing has an actual press fit rather than the factory slip fit.
Any questions, feel free to ask.
Asking 3000 shipped for everything.
Old 03-14-2014, 02:51 AM
LT1Formula's Avatar
Re: 93 M29 T56---freshly rebuilt by Texas Drivetrain Performance
Just so you guys know Jason at TDP is hands down one of the best shops for manual transmissions and rear ends. People all over the country send their stuff to him. He build them strong and right. Good luck with the sale OP.
Old 03-15-2014, 12:33 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
Thanks for the props, i did a lot of research on the different T56 builders and TDP was always at the top of the list.
Old 03-17-2014, 07:10 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
bump ttt, i now have a stock LT1 flywheel and the slave cylinder spacer that will come with the trans. And the clutch comes with ARP pressure plate bolts.
Old 03-20-2014, 08:57 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
I have my t56 sitting up at TDP right now...been there a year...paid off for awhile...BEST SHOPS for t56 hands down and I paid almost as much as your selling yours just for the build not to mention the trans to begin with and the extra parts....
GOOD DEAL RIGHT HERE
Old 03-29-2014, 07:30 PM
Want a title? Post!
William Gray's Avatar
Car: 91 RS Camaro
Axle/Gears: Stock, Motive 373,and Detroit Locke
do you have pictures how long ago rebuilt
Old 03-29-2014, 07:35 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
Trans was rebuilt early last year, I picked it up from TDP around June/July of last year and its been sitting in the garage ever since.
I can get some pics tomorrow for you.
Old 03-31-2014, 04:10 PM
Want a title? Post!
Car: 91 RS Camaro
thanks that sounds good
Old 04-02-2014, 08:42 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
Do you have a link for what all is included in stage two? Is it a stock flywheel & clutch?
Old 04-02-2014, 08:46 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
Here is a link to TDP website, along with the stage 2 build, this one has all new bearings and had the main shaft journal repair, where they weld it then machine it back down so that its an actual press fit rather than the factory slip fit, so it increases strength and durability.
http://www.texasdrivetrainperformanc...hp/t56-6-speed
And, yes, its a stock steel flywheel and stock LT4 style clutch.
Old 04-10-2014, 11:33 AM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
bump ttt
Old 04-17-2014, 01:25 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
bump ttt 2800 shipped is a hell of a deal for a basically bolt in T56 kit minus the hydraulics, which are easy to source.
Old 04-22-2014, 09:49 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
Bump ttt, willing to sell the extras separately if somebody wants just the trans itself.
Old 04-23-2014, 05:03 PM
Want a title? Post!
Car: 91 RS Camaro
Are you still sailing the tran mission I'm look for t56 for my camaro
Old 04-23-2014, 05:04 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
Yes sir, still got everything. Ready to go.
Old 04-24-2014, 05:49 PM
Want a title? Post!
Car: 91 RS Camaro
Ok what are you sale all the parts
Old 04-24-2014, 05:53 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
I'm asking 2800 shipped for everthing. Which is a very good deal.
Also,if you pay via Paypal it will be plus the 3% fee they charge. Shipping will be via FedEx ground.
Old 04-24-2014, 06:10 PM
Want a title? Post!
Car: 91 RS Camaro
Old 04-26-2014, 10:26 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Axle/Gears: 8 3/4
SOLD, Thanks. Please delete thread.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
RyanJB
Members Firebirds
39
11-20-2018 03:30 PM
DARKmj16
09-09-2015 04:07 PM
scottmoyer
09-07-2015 07:06 PM
GeneralIesrussi
09-03-2015 03:23 AM
Quick Reply: [TX] 93 M29 T56---freshly rebuilt by Texas Drivetrain Performance
