Comp Retrofit Roller Cam Kit
Old 03-17-2014, 07:04 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I've got a retrofit roller cam set up for a non-roller SBC block. The lifters are brand new in the box. The part number is 853-16. These are $475 retail.
The Comp roller cam is used but in good condition. It is a great cam for a carbed motor. Part number is 12-420-8 and the grind number is CS 270H-R10. Specs are .500 lift on both the intake and exhaust with a 215 duration at .050. Lobe separation is 110. This is a retrofit roller cam that must be used with a cam button. I am including two new ones...a solid and a roller.
The timing set is a Comp as well. It's adjustable and I'm throwing in a new thrust bearing to protect the block. I didn't use it but you might want to. The timing set has about 3000 miles and is in very good condition.
I'll sell the all the parts listed above for less than the cost of the lifters. $450 plus shipping. I'll eat any PayPal fees.
Attached Thumbnails Comp Retrofit Roller Cam Kit-mvc-001f.jpg   Comp Retrofit Roller Cam Kit-mvc-002f.jpg   Comp Retrofit Roller Cam Kit-mvc-005f.jpg
Old 03-21-2014, 05:20 PM
wesilva's Avatar
Transmission: 200R4
Re: Comp Retrofit Roller Cam Kit
Bump..
Old 03-21-2014, 10:25 PM
Fast83z28's Avatar
Car: 83z28
Transmission: t-5
How much for just the lifters?
Old 03-21-2014, 11:00 PM
wesilva's Avatar
Transmission: 200R4
Currently have a sale pending. If it falls through, I'll quote a price on just the lifters. Thanks.
Old 03-23-2014, 12:48 PM
Fast83z28's Avatar
Car: 83z28
Transmission: t-5
ok
junkcltr
08-02-2019 11:12 PM
gixxer92
09-01-2015 04:32 PM
bdads
08-24-2015 06:01 PM
anesthes
08-08-2015 09:37 PM
Quick Reply: Comp Retrofit Roller Cam Kit
