EBL ECM and Accessories
Old Mar 24, 2014 | 08:03 PM
patrick92z28's Avatar
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
I have an EBL ECM w/port mod, knock filter, and 4way buffer. I used this setup to tune my 355 TPI which was in my 92 Z28. This is a great setup which is easy to use and makes tuning your own ECM very easy. I have everything needed to install this in any Camaro or Firebird running a TPI system. Dynamic EFI is who I purchased this through and they are a great company with the best customer service! I am asking $300 +shipping.
Old Mar 25, 2014 | 12:43 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: EBL ECM and Accessories
Would you sell the EBL separately? What would you want for that? Pics?
Old Mar 25, 2014 | 01:26 PM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
I would really prefer to get rid of everything at one time. I will post some pics this evening.
Old Mar 25, 2014 | 01:31 PM
Ok
Old Mar 25, 2014 | 10:03 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Also interested in the EBL without the laptop.
Old Apr 2, 2014 | 09:27 PM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
Bump
Old Apr 10, 2014 | 07:17 AM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
Originally Posted by patrick92z28
I have an EBL ECM w/port mod, knock filter, and 4way buffer. I used this setup to tune my 355 TPI which was in my 92 Z28. This is a great setup which is easy to use and makes tuning your own ECM very easy. I have everything needed to install this in any 90-92 Camaro or Firebird running a TPI system. This will work with any speed density setup that utilizes the 90-92 ecm connectors. Dynamic EFI is who I purchased this through and they are a great company with the best customer service! I am asking $350 shipped.
Attachment 274474
Edit, Price change and BUMP!
Old Apr 13, 2014 | 02:15 PM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
Bump!
Old Apr 16, 2014 | 11:59 AM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
Bump
Old Apr 17, 2014 | 07:29 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Attachment 274474
Why are you selling?
-- Joe
Old Apr 27, 2014 | 11:59 PM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
Dropped a lifter and trashed my cam then i found a good deal on a 6.0 LS and decided to swap it over so no need for the EBL anymore.
Old Apr 28, 2014 | 02:57 PM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
Attachment 274474
Bump!
Old Apr 28, 2014 | 04:21 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
I have a 92 TA with tpi, sd and a 7730. Does this plug right in? What's the knock filter and 4 way buffer used for?
Old Apr 28, 2014 | 04:59 PM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
There are a couple pins that have to be moved on the connector but it is really easy(if I could do it I'm sure anyone can)and then wire in the buffer and knock filter. The buffer is for the vehicle speed sensor and the knock filter is for your knock sensor as they read at a different pulse rate compared to the 7730.
Old Apr 28, 2014 | 07:04 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The ECM in the first post is a 165 or 746 donor. You would need to completely repin the '730 harness (3 connectors) to that ECM (2 connectors)
Not that it would take more than 20 minutes..
-- Joe
Old Apr 29, 2014 | 09:08 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
-- Joe
Thanks, that clears things up.
Old Apr 29, 2014 | 01:16 PM
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
SOLD!!! Thanks Y'all!!!!!
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
