[WI] Complete part out of 89 RS Camaro
Car: 1990 Camaro R.S Convertible.
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Completely parting out a 1989 Camaro RS. 305 / 5.0 automatic TBI. 62,000 miles.
T-tops. No winters ever, always stored inside. Car was rear-ended so it is being parted out. Still runs & drives. Let me know if anyone is interested in parts. Located south of Green Bay, Wis
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Complete part out of 89 RS Camaro
What condition is the engine harness in? How much would you want for it?
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Rear view mirror with map lights, brake pedal rubber cover and nose emblem?
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Javier: I have some general pics on my phone if needed.
Lurbie: All wiring is intact & has never been modified. The car is a TBI 305 / auto. I'll have to get back to you on engine harness price.
91 Camaro racer: The mirror is there, I'll check to see If the pedal rubber is worn, or are you looking for one in any condition? The nose emblem may be scratched as the car ended up pretty close to a pine tree & cracked the front bumper cover a little. I will check on that too. Thanks.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
what color is the inside?
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Interior carpet is black. Seats are black & grey.
As far as the serpentine setup, i'd like to see if I can sell the motor complete before I take that stuff off. Make an offer on it otherwise & i'll consider it. Thanks!
any luck with the pics for the mirror, pad, and emblem?
Car: 1992 Camaro Z28
I've looked and looked but I still don't know if it's possible, but the rubber piece that surrounds the e-brake handle, the one that is split and the handle goes through, is it black and if so, is it possible to take out just that rubber piece (it might be two pieces, idk)? Mine ripped and I don't want to buy the whole lower console for that one rubber piece.
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Give me a couple days & i'll get back to you on the parts. If you'd like pictures, message me your # or email address & i'll send them.
I will look at it & let you know. Thanks.
Car: 89 Camaro
That will work for what I am wanting to do. Let me know how much. I'm not in a rush to get it, but I'd like first dibs on it when it's available.
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
T top headliner any color
Sun visors (if black)
Upper center console?
Rear hatch pull down motor cover if it isn't destroyed.
Side ground effect and rear bumper emblems if they aren't broke.
Lmk
Any associated hardware as well.
Lmk
Car: 1991 camaro
Engine: built 350
Transmission: super t10 4 speed
Axle/Gears: 4.10
what colors the car and what condition is the front bumper and lower spoiler
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Does the car have the dual snorkel intake? The one that pulls from in front of the radiator? How much for the plastics and the sheet metal that goes between the nose and radiator support?
Car: 84 z
Engine: 383
Transmission: 700r-4
Axle/Gears: 2.77 9 bolt
Will you part out the gauge cluster, specifically the speedometer? What's it look like, and how much for it?
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Headliner & visors might be sold. Counsel is in great condition, armrest is in good condition, but has a little "dimple" in it, but is not cracked.
I think the hatch pull down motor cover is bent.
Side ground effect emblem is in good condition, rear bumper one may be damaged, but I will check.
The car is black, the front bumper cover has a small crack in it next to the blinker light. Bumper ground effect might be cracked, but repairable (ill have to check)
The car does not have a dual snorkel intake. What plastics & sheetmetal are you asking about between the nose & core support? Do you mean the bumper reinforcement? That's In good condition & the plastic that goes on that is good too.
No, I do not want to part out the gauge cluster at this time. If it doesn't sell complete, I may still consider that. Thanks.
Car: 89 Camaro
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
I need a drivers side spindle.
46268
thanks-
46268
thanks-
Car: 1989 Camaro RS T-Top
Engine: 350 four main bolt
Axle/Gears: Factory
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Car: 1985 Pontiac Trans Am'
Engine: 305 LB9 V8
Axle/Gears: 3.23 9bolt BW
How much for seats shipped to 04412?
Car: 1989 Camaro RS
Transmission: Automatic
what color and style are the door panels?
do you have the control assembly for trunk lid, seat belt set?
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Door panels are standard original 89 RS black panels in good condition with no cracks in the upper plastic.
Are you asking about the pull down for the trunk lid? That was damaged in the accident.
Seat belts are still in the car & are standard grey with black receivers in good condition. (the car was always stored inside & never driven in winter)
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Serpentine up for sale?
Car: 93 Z28/ 92 Z28 Purple Haze conv
Engine: LT1/305TPI
Transmission: 6 Speed man/ 4 sp auto
I need the tpo plastics for the door panels for an 87 IROC. Price shipped to 61080. Thank's, Bill.
Car: '92 Camaro RS
Engine: 305 TBI
I saw that someone else inquired on the fuel tank vent value. You were going to check but I don't see a response. Do you still have it? Was it damaged? I'd be interested in it.
Terrell351
Jun 13, 2021 01:13 PM
The_Phoenix
Sep 3, 2015 10:56 PM
