NIB procomp hsr ( standard or vortec heads)
Old Jun 30, 2014 | 12:34 AM
project89's Avatar
i bought 3 of these and im not using the 3rd it is still new in the box , i only opened the box to check the contents and then put it on the shelf
intake comes drilled for conventional head mounting but has bosses so it can be drilled for vortec pattern
235 + shipping Firm!!!!!! (due to the holiday i probably will not be able to ship till after the holiday weekend, therefor i will not accept payment till after the holiday were i know there will be no delay in shipping it off to the purchaser)
intake and gaskets only
new on fleabay they go for 289+shipping
here is one bolted onto my twin turbo engine
the second one went to a friend and is sitting ontop of a 406ci sb
this 3rd one was supposed to make it onto my truck but ive decided to keep it stock
Old Jul 1, 2014 | 07:15 AM
project89's Avatar
Re: NIB procomp hsr ( standard or vortec heads)
ttt
Old Jul 2, 2014 | 09:17 AM
project89's Avatar
ttt
Old Jul 3, 2014 | 03:40 PM
project89's Avatar
ttt
comone guys i know somone wants/needs this , and i need it sold so the wife wont kill me when i order the parachute for my car
Old Jul 3, 2014 | 05:16 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Someone should put this in a book or something.
Old Jul 4, 2014 | 01:26 PM
project89's Avatar
ttt
Old Jul 4, 2014 | 03:02 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Well I have the 406.I just need a way to get it to fit under my stock hood .
Old Jul 4, 2014 | 03:11 PM
project89's Avatar
it may or may not fit under a stock hood . i still have my stock iroc hood i could toss back on my car and let u know if it fits if that would help
i can tell u now it didnt fit under my 4 inch amd steel cowl hood cause the way the designed the underside of it , the aircleaner section built into the amd hood hit the very front of the tb
Old Jul 4, 2014 | 03:13 PM
project89's Avatar
i just bought the wife a ford explorer for her to drive since everything else we own is a stick and she hates it ( besides the camaro which she wont drive anyways cause shes afriad of it ) hopefully that will keep the bitching to a minimum when the next go around of parts gets ordered
Old Jul 4, 2014 | 08:29 PM
racingdragracer's Avatar
Car: 1969 camaro
Engine: 90 TPI
Transmission: 400turbo
What is included? Fuel rails? AFPR?
Old Jul 4, 2014 | 11:00 PM
project89's Avatar
intake and gaskets only , u can buy the fuel rails online for 55$ and use the regulator of your choice
or u can buy the holley kit for however much that costs .
buying the 55$ rail kit and or own regulator saves u a bunch of money
Old Jul 5, 2014 | 06:31 PM
project89's Avatar
back to the top
my stock hood fits with this
Old Jul 6, 2014 | 07:44 AM
project89's Avatar
will take trades, looking for th350 parts , 3/4 speed shifters , nitrous bottles, suspension components etc
Old Jul 7, 2014 | 11:44 AM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
what kinda th350 parts are u looking for?
Old Jul 7, 2014 | 12:21 PM
project89's Avatar
converter , b&m th350 swap kit or one of the various th350 swap x members , trans-brake/full manual valve body
Old Jul 8, 2014 | 08:33 AM
project89's Avatar
ttt
Old Jul 8, 2014 | 03:27 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
How are the ports on this? Do they need some work like the others?
Old Jul 8, 2014 | 03:42 PM
project89's Avatar
depending on what heads ur using yeah u will have to do some work on the ports, honestly i think its no worse then the holley version, except this has room to be ported further
i sent my holley back to summit after getting my hands on the first procomp unit
Old Jul 8, 2014 | 06:04 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
What intake base does this work with?
Old Jul 8, 2014 | 10:54 PM
project89's Avatar
its a complete intake base and upper plenum
Old Jul 8, 2014 | 11:27 PM
lawdog49's Avatar
Car: 91 Z28
very interested. pm me some pics of the actual unit you have left. and info about how it fits under a stock hood.
Old Jul 9, 2014 | 01:56 AM
project89's Avatar
it is damn close to the stock hood , and by close i mean like 1/8th inch clearance
i can get u pics of the actual unit in the morning/early afternoon i have to run over to the shop first thing in the am to grab some stuff for shipping quotes for a bunch of stuff
Old Jul 9, 2014 | 12:31 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
is this still available? Where are you located?
Old Jul 9, 2014 | 05:26 PM
project89's Avatar
i have a pending deal on this guys , ill update if it falls threw
Old Jul 25, 2014 | 10:44 AM
86Base's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 383 Stroker
Transmission: stage 2 2004r
Axle/Gears: 3.55
hi is this still available? does it take any modifications to bolt on to vortec or regular heads?
Old Jul 31, 2014 | 09:11 AM
project89's Avatar
still available , in order to use on vortec heads u have to drill 8 holes in the manifold base
the manifold has the bosses for the vortec pattern already there u just have to drill them. 10 min job with a drill press , lil longer if u have to do it with a regular drill
will bolt directly onto a std pattern head or std pattern raised runner head
Old Jul 31, 2014 | 08:11 PM
Car: 1969 camaro
Engine: 90 TPI
I have a new B&M 1/4 stick and a TPI nos plate
Old Jul 31, 2014 | 09:51 PM
project89's Avatar
pending sale
Old Aug 1, 2014 | 09:04 PM
Jackrabbit501's Avatar
Car: 1986 Camaro
Engine: 355 tpi
If it falls through how much for shipping to 93720?
Old Aug 3, 2014 | 01:20 AM
xrgoose's Avatar
Car: 88 Trans Am
Transmission: 4 speed auto
Do you still the intake?
Old Aug 4, 2014 | 12:36 PM
project89's Avatar
im currently holding it for somone till wensday, if that falls threw jackrabit is next in line and then u
Old Aug 6, 2014 | 11:23 AM
project89's Avatar
sold !!!!!!!!!!!!!!!! thanks tgo
Old Aug 13, 2014 | 11:00 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Can you direct me where to buy the fuel rails for $55 you mentioned without the regulator?
Old Aug 13, 2014 | 04:12 PM
project89's Avatar
seller is out of stock but send him a msg on ebay and see when he will get more in
http://www.ebay.com/itm/SMALL-BLOCK-CHEVY-ANODIZED-RED-BILLET-FUEL-RAILS-W-FITTINGS-SBC-/140922570233?pt=Motors_Car_Truck_Parts_Accessories&hash=item20cfa3c5f9
Old Dec 19, 2014 | 09:23 PM
91 rally sport's Avatar
Car: 85 iroc z, 03 ram 1500
Engine: 305 tpi, 287
Transmission: WC T5, NV3500
Axle/Gears: 3.42, 3.55s
Pm'd
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
