parting 1989 firebird formula had tpi 5 speed
Old Mar 11, 2015 | 04:02 AM
89irocz355's Avatar
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
engine harness $150 shipped
4 wheel disk prop. valve $40 shipped
ws6 steering box $75 shipped
much more
Old Mar 11, 2015 | 09:31 AM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Re: parting 1989 firebird formula had tpi 5 speed
DO you have a dual fan set up with the mounts?
Old Mar 11, 2015 | 07:47 PM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
Center console?
Old Mar 11, 2015 | 07:58 PM
89irocz355's Avatar
fans are gone
Old Mar 11, 2015 | 09:57 PM
mstng5pt0klrz28's Avatar
Car: 1985 Z28
I'm looking for just the reservoir with hose for the clutch master...
Old Mar 14, 2015 | 09:01 AM
89irocz355's Avatar
got one. 15 picked up
20 shipped
Old Mar 14, 2015 | 08:25 PM
19875speed's Avatar
Car: 1989 Formula Firebird
Transmission: 5-speed
Axle/Gears: 3:45
Do you have the canister that holds the air filter?
Old Mar 14, 2015 | 11:23 PM
ledman66's Avatar
Car: '85 Trans Am
Engine: 305 LG4 4BBL
TPI throttle cable?
Old Mar 15, 2015 | 01:04 AM
rick90gta's Avatar
Car: 1990 GTA
Engine: 5.7L TPI SLP Runners Accel 24lb Inj
Transmission: 700R4 Upgraded Internals, Shift Kit
Axle/Gears: Borg Warner 9 Bolt, 3.27 Ratio
clutch and brake pedal assembly?
Old Mar 19, 2015 | 09:35 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Can you provide the #'s off the steering box and confirm if any slop? Thx!
Old Mar 20, 2015 | 11:45 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
May be interested in gauges from this car that you have listed in interior thread as well, thx.
Old Mar 21, 2015 | 07:41 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Stock shifter?
Old Mar 21, 2015 | 10:41 AM
89irocz355's Avatar
the box is tight. no slop. the car only has 86,000 orig. miles. i have the gauges. where on the box are the numbers. i will remove it in the morning and look. it is ws6 car. it has the 36mm sway bar. i checked it with caliper.
Old Mar 22, 2015 | 10:57 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
Should have XH stamped on end I believe, however, if car has the 36mm sway bar and 16" wheels, it's probably safe to say it's the XH box. I'll take it and possibly gauges, will PM you for details. Thx!
Old Mar 24, 2015 | 03:37 AM
89irocz355's Avatar
Originally Posted by ledman66
TPI throttle cable?
25 shipped
Old Mar 24, 2015 | 03:40 AM
89irocz355's Avatar
the car being orig. a 5 speed but he put a 6 speed in it and i believe the throw is different on pedals
Old Mar 24, 2015 | 10:36 PM
NASCAR's Avatar
Car: 89iroc/03dakota
Engine: 350&4.7
Transmission: auto
Axle/Gears: 2:77 & 3:55
looking for 9bolt rear with poise,3 something gears and discs brakes would u ship to 70737
Old Mar 29, 2015 | 11:23 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
Received steering box and gauges-super fast shipping, box already installed and works great!
Old Mar 30, 2015 | 05:58 PM
cnuno123's Avatar
Car: 1987 Formula Firebird
Engine: L98 5.7 350
Do you have these door panels
Old Mar 30, 2015 | 07:12 PM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
I am going to send you a PM.
Old Apr 7, 2015 | 09:59 AM
3GEN90's Avatar
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
What is the condition of the front turn signals?
Price + shipping to 12564
Old Apr 7, 2015 | 10:01 PM
gearheadotaku's Avatar
Car: '91 Firebird
Engine: 305 TBI w/LT1 cam
Transmission: T5 swapped in
Axle/Gears: 9 bolt 3.27 w/discs
this had aluminum calipers out back right? If so I'll take the prop valve
Old Apr 9, 2015 | 08:52 PM
formula00ra's Avatar
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
what are the seats like? standard or custom? color, condition?
Old Apr 10, 2015 | 12:23 PM
89irocz355's Avatar
i think they are good. i will remove and send pics
Old Apr 11, 2015 | 10:17 PM
chad87sc's Avatar
Car: 1987 sport coupe camaro
Engine: 355
Interested in the proportioning valve
Old Apr 12, 2015 | 08:00 AM
89irocz355's Avatar
[QUOTE=chad87sc;5902043]Interested in the proportioning valve[/QUOTE
sent a pm
Old Apr 13, 2015 | 07:03 AM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
Do you have the A/C compressor-serpentine air pump bracket for this car? What condition and how much?
Thanks,
Scott.
Old Apr 14, 2015 | 03:54 PM
89irocz355's Avatar
heres a pic
Attached Thumbnails parting 1989 firebird formula had tpi 5 speed-001.jpg   parting 1989 firebird formula had tpi 5 speed-002.jpg
Old Apr 14, 2015 | 04:24 PM
chad87sc's Avatar
Engine: 355
heres a pic
I've never used one how do you adjust it? Its this a factory prop valve?
Old Apr 14, 2015 | 05:24 PM
89irocz355's Avatar
This is a factory one. It's for the 4 wheel disc. ..I have no idea about adjusting them
Old Apr 15, 2015 | 09:58 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Catalytic hanger?
Old Apr 25, 2015 | 11:22 AM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
do you happen to have a lower shift boot and shift plate for the t5
Old Apr 27, 2015 | 12:58 PM
RickD92rs's Avatar
Car: 1991 Z28
Engine: TPI 5.0
Transmission: 5-Speed
Axle/Gears: stock
Do you have the 6speed that was in the car?
Old Apr 29, 2015 | 12:53 AM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
Going to assume that was a maf setup or did someone put the newer speed density setup in it? Interested in the harness if it was SD.
1992 Trans Am
May 10, 2023 07:19 PM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
1nastygta
Aug 8, 2015 07:38 PM
