[AZ] Scoggin-Dickey Vortec Intake Manifold and more
Admins - Edit: These parts are now all sold, and shipped with the exception of the exhaust manifolds. This thread can be closed. I'll re-list the exhaust manifolds along with some other stuff in another thread when ready.
I unfortunately totaled my 1990 Camaro last year. I managed to salvage some parts, and am finally getting around to listing them for sale. I have a Scoggin-Dickey Vortec intake manifold that was brand new at the time of the accident. I had just had a new crate engine installed, and had driven the car less than 20 miles before the unfortunate incident. I just listed the manifold on Ebay, but thought I'd try here as well. It is Jet-Hot coated in a dark charcoal gray color.
I have other engine parts as well that I haven't listed yet, including a silver cerakoated upper plenum, and SLP aftermarket runners, Jet-Hot coated stock exhaust manifolds, and a 52mm throttle body. I can't think of the name of the company who bored out the throttle body, but it is the one that did all of them back in the day. I had this one done last year. They actually tried to talk me in to a new aftermarket one, but I was trying to go old school at the time.
Hit me up with any questions.
http://www.ebay.com/itm/122007322922?item=122007322922&viewitem=&vxp=mtr
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Re: Scoggin-Dickey Vortec Intake Manifold and more
You sir are my savior! Will the water neck come with it or no? All the factory 85 maf style tpi should all bolt in correct? Contact me at 5413409876!!!!
OK guys here are some pics of everything. I've been getting a lot of PMs, and it is getting a bit confusing to try to explain things, so I thought this would make it easier.
Also here are some quick prices. The Vortec manifold is sold. The rest I haven't even made ads for since there was interest here.
So here are some quick deal options:
1. SLP cerakoted runners, and matching cerakoted plenum, and throttle body. $400
2. Same stuff from number 1 with the stock cerakoted base, fuel rails, and injectors. $500
3. Throttle body alone. $160
4. Hurst shifter, and cover plate. $75
5. Stock exhaust cerakoted manifolds. $75
Shipping is not yet determined. I think once someone truly wants something I will box it up, take it to my local UPS store, and get quotes. Then contact the buyer back, and see if they still want it with the additional shipping cost.
Link edited. It should work now.
https://goo.gl/photos/KwZrb1pNSXXfuTEZ7
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
actually i have been talking to the seller since day one for the parts just waiting on the shipping coute vortec base, slp runners , plenum
OK guys. Here is the order based on when I received your PMs.
1. Chains
2. 1BADZ28SD
3. Boobye
To make sure everything is clear, and out in the open, the Vortec base is already sold to Mr.ChevyStroker. I already received his money, and am shipping it on Saturday.
So the deal for #2 is for the stock base manifold, and the other parts listed. I just want to make sure that is what you want. Reading some of the PMs I wasn't sure if that was understood.
I have Boobye's zip code, but I need the others. I will box everything up on Saturday, and get it weighed, and have estimates for all of your zip codes. I will then give each buyer the chance in order starting with Chains to accept or decline based on the total. I expect the shipping to be pretty hefty due to the weight, so I'll get quotes for USPS and UPS ground, which are the two options at my local UPS store.
Thanks guys. More info to come on Saturday.
1. Chains
2. 1BADZ28SD
3. Boobye
Sorry I didn't get a chance to get back on here yesterday guys. I did get manage to get the shipping quotes done.
After I got everything boxed up I logged back in to the site here to get your zip codes, and looking back through the PM's I see some conflicting info. I thought all of you wanted the throttle body, plenum, SLP runners, base, fuel rails, and injectors for the $500 dollar price.
So here is how everything is currently boxed up:
Box #1 has the throttle body, plenum, SLP runners, and base. Everything is bolted together as one unit as this kept the box to the smallest size for shipping.
Box #2 has the fuel rails, and injectors.
Chains: Box #1 shipping is $53.61. Box #2 shipping is $27.94.
1BADZ28SD: Box #1 shipping is $34.21. Box #2 shipping is $16.95.
BOOBYE: Box #1 shipping is $38.45. Box #2 shipping is $18.60.
Getting the TPI setup properly protected, and boxed was kind of a pain, and I think at this point it is what it is. For now please consider the cost of $500, with the addition of your individual shipping charges, and let me know.
So in order with Chains first, then 1BADZ28SD, and then BOOBYE let me know if you want it. Please reply here in the main thread so everyone can see, and to me via PM. If nobody wants it in the current packaged condition, and price point then I will consider breaking things up.
Also one person mentioned wanting the valve covers. You can have those for the cost of shipping. We can work that out separate.
BOOBYE mentioned wanting the shifter. That we can work out separate as well.
Thank you,
Chris
Thank you,
Chris
Details you should be aware of. The base, fuel rails, and plenum are originally from a 1988 Trans Am GTA. The throttle body is the early style. The runners have the hole for a cold start injector, but I have a block off plate installed so you can go either way. The fuel rail has the hole for a cold start valve, but I have a custom aluminum plug, with rubber seal installed to fill the hole, so you can go either way. Because the throttle body is the earlier style you will need the early style throttle cable. All bolts are stainless. I used anti-seize on each bolt so they don't seize in the aluminum. The bolts that hold the TPS on to the throttle body are 10/32 thread pitch. I tapped out the bolt holes from the original impossible to find size. You can't get the original size bolts from GM for this anymore, and nobody makes them.
OK guys. Chains, and 1BADZ let me know. If neither of you want it will go to BOOBYE, but of course in fairness you were both ahead in line, so the option is yours. If you can please let me know by tomorrow evening.
Chris
Chris
Admins: Everything in this thread is now sold except the exhaust manifolds. I think we can consider this thread closed now. I have some other stuff to eventually list, but will start a new thread for that at some point.
evo-offer
Mar 18, 2016 05:50 PM
