[WA] Speed density tpi intake
Old Nov 17, 2017 | 11:12 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Selling my tpi intake with 24lb ford injectors and BBK adjustable regulator bought the injectors refurbished and flow tested ran them for 15k miles. Intake was originally a MAF set up but I did the 9th injector delete for my speed density swap. Comes with the factory hard lines/brackets as well as the rubber flex hoses to connect to the frame rail lines. Including the distributor cover, missing 2 of the screws for it. The intake could use a new coat of paint, runners are chipping. Tps and iac not included, throttle body coolant line have been chopped off for the bypass.-$100+shipping
Lt1 cam, short nose style so it will drop into any 1 pc roller sbc without modification. Easy power pickup for tpi and even tbi engines, no tuning required. [SOLD]
With this combo i made 233hp on a mustang dyno to the wheels on an Lb9.
Old Nov 18, 2017 | 11:20 AM
W30rocks's Avatar
Want a title? Post!
Re: Speed density tpi intake/lt1 cam
Pmd you about camshaft
Old Nov 18, 2017 | 06:07 PM
Zipedoda's Avatar
Did you get my PM on the tpi?
Old Nov 18, 2017 | 10:55 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I sent you a reply
Old Nov 20, 2017 | 09:04 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Cam is SOLD, W30rocks enjoy
Old Nov 21, 2017 | 12:54 PM
W30rocks's Avatar
Want a title? Post!
thanks man!!!!
Old Dec 20, 2017 | 10:28 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Bump
Old Dec 25, 2017 | 09:59 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Bump, price adjusted
Old Jan 20, 2018 | 07:36 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Bump for the new year
Old Mar 5, 2018 | 05:15 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Bump
Old Mar 8, 2018 | 06:46 AM
91rs1022's Avatar
Car: 89 Camaro RS
Transmission: 5 Speed
Would you be interested in selling the injectors, hard fuel lines, and regulator separate?
Old May 9, 2018 | 07:52 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I never saw your post on here sorry man, the price is lowered to 100 bucks plus shipping I need to sell the whole assembly but I know I paid more than double for the correct lines and injectors/regulator, you can always resell the intake parts. My wife is hounding me to get it out of the house because its taking up space
Old May 15, 2018 | 08:08 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Bump
Old May 22, 2018 | 01:06 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Bump
Old May 22, 2018 | 04:00 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Bump
Aaahhh, wifes are the same around the world.
