[IL] 1LE 10 Bolt Rearend Complete with Brakes
Transmission: Pro-built 700R4
Re: 1LE 10 Bolt Rearend Complete with Brakes
Here we go using "1LE" as a selling point when it is not needed, nor is it a unique part specific to the 1LE RPO.
Transmission: World Class T-5
Axle/Gears: BW 3.45
I'm looking for a 1LE lighter.
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Yes..it would be a G92 option rear axle, but if I recall correctly, it could be either a 3.23,or a 3.42...
Are you saying the G92 only came on 1LEs?
Car: 1988 IROC-Z
No...I'm saying the only "special" thing about a 1LE axle is it's a G92 code, which wasn't exclusive to the 1LE.
Transmission: A4
Axle/Gears: BW 3.45
Seriously, what the OP might want to say is he has a 10 bolt with PBRs, basically any 4 wheel disc rear from '90-'92.
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
Can you please post pics of the rear enD and specs? What gear ratio is it?
Car: 1988 IROC-Z
LC2 TECH
51
Mar 21, 2017 08:50 PM
cobrakiller1989
Sep 11, 2004 11:47 PM
bad camaro RS
Oct 14, 2000 05:28 PM
