[GA] Complete TPI setup
Old Oct 25, 2018 | 11:57 AM
dixiepc's Avatar
Complete TPI setup
TPI manifold for early small block heads
Proper brackets and pulleys for mounting air filter on throttle body
Brand New unused labeled "Chevy Thunder" stand alone speed density harness wired for heated O2 sensor and two electric fans with installation CD
#01227730 computer and Delco ANJF eprom
Correct distributor without cap or ignition module
New reman 24 lb LT1 injectors
JTR mechanical speed sensor
No knock sensor but all others included
Cleveland GA
$1200
Old Oct 25, 2018 | 12:15 PM
dixiepc's Avatar
Re: Complete TPI setup
Old Oct 25, 2018 | 12:16 PM
dixiepc's Avatar
Not having any luck putting pictures up.
Old Oct 25, 2018 | 12:24 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Is it an aftermarket base/runners or just a stock tpi unit?
Old Oct 25, 2018 | 02:10 PM
dixiepc's Avatar
Stock from an early TPI Corvette.
Old Nov 17, 2018 | 08:46 PM
dixiepc's Avatar
Bump
Old Nov 17, 2018 | 08:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
That’s a lot for a stock tpi setup
Old Nov 17, 2018 | 10:47 PM
dixiepc's Avatar
Not really with everything that's included. Bracketry, pulleys, speed sensor, brand new wiring harness, etc.
Old Nov 18, 2018 | 11:58 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
You will never see a stock tpi unit sell for that price be realistic most you will get for that is 300-500 max. Its 30 year old technology
Old Nov 19, 2018 | 07:05 AM
dixiepc's Avatar
You price your stuff and I'll price mine.
Old Feb 2, 2019 | 06:39 AM
leachbuz's Avatar
Car: 1986 trans am; 1997 trans am
Engine: 5.0, 364 ci procharged
Is this for sale still?
Old Feb 3, 2019 | 10:53 PM
dixiepc's Avatar
Yes, it is still available.
Terrell351
Jun 13, 2021 01:13 PM
jstoltz
Jun 15, 2010 10:27 PM
89irocz355
Jun 3, 2006 09:30 AM
