[RI] Engine Drivetrain Suspension ----> too much to list.
Old May 3, 2019 | 12:20 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
SOLD: Air Cleaner V6 MPFI TPI Upper Snorkel:
Old May 3, 2019 | 07:17 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: Air Cleaner V6 MPFI TPI Upper Snorkel
John, I have no Camaro but are these same or different than a V-8? looks same but IDK
Old May 3, 2019 | 11:25 AM
John in RI's Avatar
The only difference between this V6 air cleaner and the V8 air cleaner is that the V6 version has the Intake Air Sensor mounted in it's neck,.... The V8 (TPI) engine has it's IAT mounted in the Plenum. Some TPI guys relocate the IAT sensor from the plenum to the air box by simply installing this Air Cleaner.
Here's some info about this modification:
http://www.austinthirdgen.org/index.php?pid=24
Old May 3, 2019 | 03:57 PM
John in RI's Avatar
Re: Engine Drivetrain Suspension ----> too much to list.
Spare Tire Air Canister / Inflation Bottle: $30 + shipping. Pulled it from the back of an 86 Trans AM. I've never used 1 and can't be sure if it's ever been used or not, it weighs about 2 1/4 pounds. ( I've got 5 of these and they all weigh the same. ) The label / cardboard is in rough shape, bracket/wingnut is included.
Old May 5, 2019 | 02:51 PM
John in RI's Avatar
$325 17x9 4th Gen Camaro SS ZR1 wheels. No Shipping, Includes the 4 centers, A few minor dings to the lip but NO damage / not warped or bent. Tires showing cracks and will need to be replaced.
Send a PM if your close enough to RI that you stop by & them pick-up.
Old May 7, 2019 | 12:15 AM
John in RI's Avatar
$150 + shipping as shown in the next 2 pics: will need a replacement "boot kit" for E-Brake lever, No Pads, no Rotors.
If you also want the E-Brake Brackets and Cables the cost is $175 + shipping. Again, needs a boot kit, No Pads and No Rotors.
Parts are HEAVY,.... if SERIOUSLY interested just send a PM that includes your ZIP code for shipping quotes.
Old May 10, 2019 | 12:31 AM
John in RI's Avatar
(SOLD ) $50 + Shipping. TBI Manifold, Blasted/Painted. Holes were all good,... but WILL need to be blown with air & 'chased' due to blasting and paint.
Old Jun 2, 2019 | 10:23 AM
Wesley Hooper's Avatar
Car: 1988 Camaro
How much is shipping for the intake?
Old Jun 2, 2019 | 11:28 AM
John in RI's Avatar
Well ----> I honestly don't know ! I'd need to know where you are first; What's your ZIP ??
Old Jun 2, 2019 | 01:51 PM
Car: 1988 Camaro
97023
Old Jun 3, 2019 | 12:46 PM
John in RI's Avatar
Yuk !
From East coast to West coast: 23 pounds, 24x12x7 = $66 for USPS Ground shipping; or $74.50 for Priority Mail.
Old Oct 28, 2019 | 10:32 AM
John in RI's Avatar
Camaro / Firebird 700R4 tailshaft: $40 + shipping. Will need a new seal, includes mounting bolts.
82-92 10-bolt Pinion flange: $20 + shipping. Blasted and painted black, nice shape. ( Add $10 if you need U-Joint caps and Pinion Nut & Washer in similar condition too )
Old Oct 28, 2019 | 10:54 AM
John in RI's Avatar
350ci 4-bolt main block. $75 (NO SHIPPING, pick-up in RI ) PN = 3970010; Think it's a targetmaster block. I've done no machine shop work to it so it will need a full work-over.
Old Oct 28, 2019 | 05:47 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Dont know if it's in the same arena as the snorkel filter. But do you have a cover for where the snorkel would go? Like the firebirds had?
Old Oct 30, 2019 | 01:53 AM
John in RI's Avatar
Yup,.... a Camaro with Carb, Crossfire, or TBI had the "tool tray" plastic filler piece. It was different in the Firebird,...... the Pontiac had a steel 'filler' panel. This is the only one I've got worth offering ($20); Of the others I've got one has a notch cut from it and the other 2 are scratched to hell. It's not perfect and has some scratches, but all the mounting holes are OK & it's in good used condition.
Old Oct 30, 2019 | 02:46 AM
John in RI's Avatar
Push / Pull Dual Aftermarket Fans ( Hayden ). $45 + shipping. Look to be 14" fans; 1 fan needs 3 1/4" for mounting and 1 fan needs 3 1/2" for mounting. ( measured from face of of the fan to back of the motor. ) The measurement is about 16" from outer edge to outer edge of the mounting tabs. Both fans tested and functional, pushing/pulling around 1200-1400CFM. Part numbers appear to be ' 20835 &/or '14-4413B3'. ( searched both numbers and found nothing ) No mounting hardware included.
Post your ZIP code for a shipping quote.
Old Oct 31, 2019 | 03:46 PM
John in RI's Avatar
SOLD: 87-88 Tuned Port Injection parts.
Old Apr 8, 2020 | 02:21 PM
John in RI's Avatar
BBK 58mm TPI Throttle Body fully loaded, installed long enough to get it a little dirty: $275 + shipping. Includes sensors, TB cooling port, and mounting bolts. If you don't need the sensors, $250 + shipping.
Post your ZIP code if your interested.
P.S. Kitten not included !
Old Apr 8, 2020 | 11:13 PM
ULTM8Z's Avatar
would you take 200 for the TB? I'm in 91207. I don't need the sensors.
Old Apr 9, 2020 | 01:05 PM
John in RI's Avatar
PM Sent !
Old Apr 9, 2020 | 05:56 PM
John in RI's Avatar
Price reduced on the Throttle Body,..... $275 with sensors or $250 without,... delivered.
Old Jul 25, 2020 | 09:32 AM
John in RI's Avatar
Bump
Old Aug 6, 2020 | 01:53 PM
zman1969's Avatar
Car: 90 Formula 350
John, didn't see ecm here? thanks
Rich
Old Aug 6, 2020 | 02:57 PM
John in RI's Avatar
Here it is Rich !
Jeremy Z28
Apr 24, 2012 12:52 AM
camarors8992
Jun 7, 2004 10:31 PM
