[Sold] Tpi 86-89 ecm 1227165
Old Jul 11, 2019 | 06:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
86-89 tpi ecm $85 shipped in the lower 48
Old Jul 14, 2019 | 05:46 PM
Engine: Lb9
Transmission: M20
Re: Tpi 86-89 ecm 1227165
Old Jul 18, 2019 | 11:12 AM
CamaroLover09's Avatar
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
Are there 2 ECMs for sale?
Is that black spot in the upper left of the 259 photo dirt on the case or is the case damaged there?
I can't read the model number in the second pic. Is it a 165 or 259? And the sticker doesn't look factory. Is it a refurb or aftermarket unit?
Have you verified that either of the ECMs work?
Sorry for all the questions but thanks for answering them!
-Chris
Old Jul 18, 2019 | 11:17 AM
Engine: Lb9
Transmission: M20
Hello Chris, the first is a 259 same as a 165 but refurbished.
the second one is I believe cardone 77-7165 both for tpi maf.
the case is dirty doesn’t look damaged. These ecms are unknown condition but if doa I’ll refund.
Old Jul 18, 2019 | 12:21 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
If one replaces a, for instance, 1989 305 AT TPI PROM (or entire ECM) with a 350 TPI PROM (or ECM) would that change be evident when a Ca SMOG Test computer is hooked up and the vehicle tested? Does the model year show up on the test equipment? Thanks.
Old Jul 18, 2019 | 01:01 PM
Engine: Lb9
Transmission: M20
The model of the ecm doesn’t show a model in the data stream. The prom does but I think it’s a hex value.
does ca even scan obd 1 ?
Old Jul 18, 2019 | 01:08 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
AFTER, I get my next smog test, I will ask my smog guy (who never cheats) and advise. What is a "Hex value"? Thanks.
Old Jul 18, 2019 | 01:10 PM
Engine: Lb9
Transmission: M20
It’s a binary value the prom uses for scan id.
Old Jul 23, 2019 | 06:40 PM
Engine: Lb9
Transmission: M20
this ecm is sold, 1 ecm left
Old Jul 26, 2019 | 08:02 PM
Engine: Lb9
Transmission: M20
Sold
gtopat
May 18, 2011 11:43 PM
busta9876
Jul 24, 2006 05:31 PM
pontiacpete
Jul 20, 2003 01:32 AM
