Car is now gone(2-9-20)
Still have parts that were removed and not sold
Tail lights are sold
Transmission is sold
Dash pad is sold
front bumper sold
Front fenders sold
Wheels are sold
rear seats sold
Headlight harness and modules sold
rearend sold
Center console sold
doors are sold
Ttop divider is sold
fuel lines are sold
sending unit and pump sold
Tank is gone
have a good set of glass ttops
grey leather interior. Front seats are in need of covers. Lumbar with manual sliders
radio pod
cluster
cluster surround
door panels
door arm pulls
headlight switch assembly
performance suspension lower dash plaque.
N10 dual cat exhaust. With flowmaster muffler attached.
shift **** auto.
harness
ecm
headlights
ground effects available.
more pics will be added at the bottom.
What do you need?
I have a 1982 T-top TA that was rear-ended... I need a new chassis to move my hardware to. I'd like to see if there may be a way to work something out.
Straight down 95 about 350mi, Port Saint Lucie, FL. I could bring a trailer... you could keep al the bits an pieces you'd like, I'd like to rotisserie to unit and move my hardware over. Is the body fairly rust free?
I will buy the radio pod if it is in fantastic condition with no broken radio/hvac mounting tabs.
Will also buy the headlight control module.
And the courtesy light socket in the driver side footwell. Just snip the wiring and give me about a foot of wire length.
I'll check on the radio pod. First time I'll be messing with a firebird interior. But I'll let you know once it's out, its condition. Along with everything else.
You can check the HVAC and radio mounts by just popping the bezel off with your fingers and dismounting the HVAC and radio. The radio mounts are usually broken.
As far as removing the entire pod, I think there are two large screws at the top (13 mm socket), and a nut and bolt waaaaay in the back on the floor. The center console has to be removed to make way for the pod to come out.
I can't remember if you have to remove the upper dash to get to those top bolts. If so then you'll have to remove the entire upper dash cover pieces. And you'll need to remove the lower dash on the passenger side to get access to more screws.
Meanwhile, you don't dare pull and tug on that pod or the plastic top frame will break. It will come out with a pinky finger when it's ready to come out.
It was cracked before I started to remove it. I cant take the blame on the upper crack.
Ya, I know, it's a common place for those to break. I was hoping for something a little nicer but I've been hoping for many years and hope isn't getting me very far.
I'll send you a PM with a list of things and we can work out a deal. Thanks.
Sent you a PM on the wheel caps, and center console lid. Thanks.
Selling the caps with the wheels. Lid prob isn't worth the effort to ship. Prob better ones out there. Most likely include it with the center console. Trying to avoid shipping as much as possible.
I am writing this from my hospital bed. I’ve suffered a stroke. As it stands now, I am goin to focus on recovery. Right arm and face are affected pretty bad. This sucks big hairy donkey *****.
