[AR] 4l80e crossmember
Old Feb 5, 2020 | 02:13 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
4l80e crossmember
I just found a site that sells 4l80e crossmembers for our cars. Paracing.com I ordered one and shipping and all was $225.00. I've looked for years and never seen one until now so wanted to spread the word.
Old Feb 7, 2020 | 12:12 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: 4l80e crossmember
I have one, check your fitment, you may have to grind on it in spots to get it to fit correctly, but it works.
Old Feb 7, 2020 | 12:22 PM
abray1's Avatar
did you get it from them. let me know everything about your 4l80e install since im about to try it. what year trans is best and what controller did you use. spare no detail.
Old Feb 7, 2020 | 12:28 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
will send you a pm
Old Feb 8, 2020 | 01:14 PM
Groot's Avatar
Please share the word, I am installing a complete LS 6.0 with 4l80e as well
Old Feb 8, 2020 | 06:27 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
I have a 4L80e crossmember with torque arm mount for the ls1 swap with 4l80e that i ground on trying to get it to fit. Gave up on it and bought the pa racing crossmember instead.
You can buy it from me for $150, it cost me $400
Old Feb 11, 2020 | 11:44 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
There's no TA mount tho. What are you doing about that??
Old Feb 12, 2020 | 06:23 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
You have to fabricate your own or buy a tunnel mounted torque arm like the bmr extreme torque arm and weld it to the trans tunnel frame area. this is the one i am running: http://m.bmrsuspension.com/?page=products&productid=402
It is cheaper to fabricate your own mount. I installed the PA racing crossmember then zip tied my stock torque arm with the bushing in between the crossmember and the stock torque arm to drive the car to the shop where they installed and welded the tunnel mounted torque arm for me. You could zip tie your stocker to the pa racing crossmember and drive it to a shop so someone could weld a mount on the back of the pa racing crossmember. My welder was crappy and i was tired of messing with it after i had some many issues with my transmission that i paid a local speed shop to do it for me.
Old Feb 12, 2020 | 07:35 PM
thatsupnow's Avatar
Lol zip tie the TA to the crossmember!! That's a new one. No I was thinking about using that piece but ended going with the hooker crossmember, it's pretty much the last crossmember I'll ever have to buy. Every transmission can be mounted to it using the different brackets
Old Feb 12, 2020 | 07:44 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
I tried that hooker crossmember and couldn't get it to line up. i had to grind on it alot and gave up on it.
Old Feb 12, 2020 | 09:20 PM
thatsupnow's Avatar
Yea if you don't all their stuff it won't line up worth a ****. I've got a 370 LS in mine with 4 position adapter plates and an adjustable transmission mount so getting it to line up was no problem.
Stroked90
Jun 4, 2017 02:21 PM
Fastime
Sponsored Vendors
May 11, 2013 05:18 AM
Jet Hydro
Aftermarket Vendor Review
55
Apr 16, 2006 11:20 PM
