[Sold] First tpi
Old Jun 2, 2020 | 05:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
First tpi
First tpi, $800 plus actual shipping in the states
3.5% pp please add.
Old Jun 2, 2020 | 07:01 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Re: First tpi
3.5% pp please add.
Assume it’s what you see is what you get? What size injectors?
Old Jun 2, 2020 | 07:20 PM
Engine: Lb9
Transmission: M20
Re: First tpi
Yes what you see is what you will get. Not sure about injectors size. The numbers on the body are hard to read.
Old Jun 3, 2020 | 12:19 PM
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Re: First tpi
What size is the TB?
Old Jun 3, 2020 | 12:24 PM
Engine: Lb9
Transmission: M20
Re: First tpi
I think it’s 835 cfm, it’s tapered opening so I don’t know what mm it is.
Old Jun 3, 2020 | 01:54 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Re: First tpi
We're the ports machined larger? I know first will machine them to match your heads
Old Jun 3, 2020 | 02:12 PM
Engine: Lb9
Transmission: M20
Re: First tpi
I think it’s 1204
Old Jun 4, 2020 | 05:03 AM
Evilokc's Avatar
Engine: tbi 305
Re: First tpi
what size motor was this on? how did it run?
Old Jun 4, 2020 | 06:42 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: First tpi
Pretty sure the Green Stripes came with three different flow rates. For example; #621031 (Green Stripe) are 42-lb injectors which is what I am currently running. I don't recall the other two sets of numbers, but one is for the flow rate of 30-lb, and the other is for the 38-lb...
- Rob
Old Jun 4, 2020 | 07:31 AM
Engine: Lb9
Transmission: M20
Re: First tpi
Old Jun 4, 2020 | 07:33 AM
Engine: Lb9
Transmission: M20
Re: First tpi
I bought this second hand and never used it. It’s hard to say what engine it was on maybe injector size would give it away but I can’t seem to find any data on them. Like rob posted he thinks there were 3 sizes. I think I’ve had the 22s and 30s if I recall right.
Old Jun 4, 2020 | 08:41 AM
Re: First tpi
Seeing the letters CAV and I immediately lean towards them being Lucas Injectors, and if one set of numbers end in 30, they may very well be 30-lb injectors because my old Sagem injectors ended in 42, which was their flow rate...
- Rob
Old Jun 6, 2020 | 07:09 AM
Engine: Lb9
Transmission: M20
Re: First tpi
Sold
smoke29
Apr 14, 2020 03:35 PM
NBrehm
Jun 3, 2014 04:17 PM
formula forever
Nov 22, 2007 06:55 PM
poorboy8
Mar 2, 2007 09:06 PM
