I have a few items for sale that I’ve purchased on here before but have decided to go in a different direction. None of them will be cheap to ship, but brakes are already boxed up and ready.
LS1 front brakes w/o rotors. Includes adapter brackets from flynbye, calipers w/ stainless lines and pads, and hubs. One of the caliper bracket bolts was missing when I purchased it but should be easy to find at NAPA. SOLD
Competition Engineering C3046 subframe connectors. These are not bolt on and require cutting the floorboard. $60 + shipping
The torque arm and driveshaft loop were purchased from @anesthes in 2004 and never installed. It appears to be an older Jegster non-adjustable unit that is a “short” torque arm and bolts to the floor. The driveshaft loop is also a bolt-in piece, and both will likely require drilling some holes. $250 + shipping
Lower Control Arm Relocation Brackets SOLD
Reason: Updating title
I have a set of stock replacement strut mounts with the oem bottom plates. The strut mounts have fewer than 500 miles on them and are still in good condition. $50 shipped
I also have a set of non-adjustable lower control arms (LCA’s) with poly bushings with similar miles. SOLD
LS1 front brakes w/o rotors. Includes adapter brackets from flynbye, calipers w/ stainless lines and pads, and hubs. One of the caliper bracket bolts was missing when I purchased it but should be easy to find at NAPA. $350 + shipping.
