SLP intake reduced
Car: 87 GTA
Axle/Gears: 3.42 posi
SLP intake reduced
$400shipped
Could use a little cleaning as it’s been sitting on a shelf for several years.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: SLP intake
On the 89 down SLP cold air induction system the ducting from the SLP air box is the factory GM ducting that SLP modified with an air flow straightener riveted into the ductwork. On the 90 up TPI SLP cold air induction system the ducting is just the factory GM ducting that all TPI Firebirds used. If installing the 90 up SLP system in a Firebird you don't even need the ducting supplied with the SLP cold air induction system. You only need the ducting if installing the SLP cold air induction system on a Camaro. Camaros don't actually need a SLP cold air induction system because their air induction system doesn't suck compared to the Firebird. Install K&N air filters and do the air box mods or Hawk's lower air box mod and it flows just as well or better than the SLP cold air induction system.
I wouldn't want to break up the unique components from an 89 down SLP system, a 89 TTA SLP system, or a dual inlet 90 up SLP system. On a 90 up single inlet SLP system the intake ducting isn't unique. It's the same part as any 90 up TPI Firebird.
Re: SLP intake
Car: 87 GTA
Re: SLP intake
@banksGTA FYI - if you do split it up, I may be interested in buying the duct
Engine: 4++,350 & 305 CIs
Re: SLP intake
I've only seen a couple of the 90-92 ducts that had been modified by SLP, the rest were just the standard GM duct like this one
firebirddude142
May 29, 2020 07:32 AM
firebirddude142
Feb 19, 2020 06:33 AM
[Sold] Rare slp tpi throttlebody
Tuned Performance
Mar 12, 2017 12:52 PM
