Ford 9” Rear Differential setup
Old Dec 11, 2022 | 05:44 PM
Steve Petroff's Avatar
82-92 Camaro Firebird rear differential Ford 9”
Ford 9” Rear differential, stock width, black coated, Bears/Strange 31 spline heavy duty axles, new Auburn Posi unit with new 3.55:1 gears, 5x4.75” bolt pattern, includes brackets for factory 90-92 rear PBR aluminum caliper disc brake setup, stainless brake lines, factory sway bar with urethane mounts, custom tubular adjustable control and panhard bars, custom tubular adjustable torque arm with integrated driveshaft loops, all urethane and spherical rod ends, custom transmission crossmember with built-in torque arm mount- $2600 CDN, zero miles!
Fits 82-92 Thirdgen 3rd Gen Camaro Firebird Trans Am Z28 IROC Formula SS
Can be modified to fit 4th Gen as well.
1982 1982 1984 1985 1986 1987 1987 1988 1990 1991 1992 1993 1994 1995 1996 1997 1998 1999 2000 2001
Old Dec 12, 2022 | 08:58 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Ford 9” Rear Differential setup
Why couldn't you be closer??
GLWS
Old Dec 12, 2022 | 09:32 AM
LOL..
Options:
* Santa ?
* Road Trip
Old Dec 12, 2022 | 10:01 AM
jkris53406's Avatar
Man if I had a passport, I would make that drive no problem. Alas, I do not.
Old Dec 12, 2022 | 10:03 AM
No passport required, drivers license ID should be sufficient to cross the border.!
Old Dec 12, 2022 | 10:31 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
what tranny does the crossmember fit and i assume your price is in American $$
Old Dec 12, 2022 | 10:57 AM
The crossmember is setup for the T56, however it would most likely work for automatic transmissions as well.
Prices are in CDN$ so even better for USD conversion. !
Old Dec 12, 2022 | 11:43 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Getting back into the USA required a passport a couple years back. I wnt to canada a lot before covid
Old Dec 12, 2022 | 11:57 AM
https://travel.gc.ca/returning/travelling-to-canada
Passport only required for travel by air, not crossing border via car etc.
Old Dec 12, 2022 | 12:04 PM
midias's Avatar
Thats going into Canada if you are coming back into the USA over land you need a passport or enhanced license
https://help.cbp.gov/s/article/Article-3618Land or Sea Travel: U.S. citizens entering the United States by land or sea are required to present a valid WHTI-compliant document, which include:
- U.S. Passports
- U.S. Passport Cards
- Enhanced Driver's Licenses
- Enhanced Tribal Card (ETC)
- Trusted Traveler Cards (Global Entry*, NEXUS, SENTRI, or FAST
- Military Identification Cards (for members of the U.S. armed official maritime business)
* The Global Entry (GE) card is only an ENTRY document and may not be used to enter Canada, Mexico or Adjacent Island.
Old Dec 12, 2022 | 12:39 PM
battmann's Avatar
man, this is a great deal for someone!
Old Dec 12, 2022 | 01:24 PM
Not sure about US States, but Ontario has enhanced drivers licenses. Time to get your passports boys ! LOL
Old Dec 12, 2022 | 01:29 PM
Thanks !!……I thought so too !
Old Dec 19, 2022 | 07:49 PM
OG IROC's Avatar
where in Canada are ya, ayeee?
Old Dec 19, 2022 | 07:52 PM
Victoria Harbour, hour and bit north of Toronto
Old Jan 8, 2023 | 11:30 AM
Bump
Old Jan 17, 2023 | 04:00 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Would you consider shipping to the US side to zip code 66203?
Old Jan 17, 2023 | 07:07 PM
Have local buyer deposit, if it falls through will let you know.
Old Jan 29, 2023 | 09:33 AM
SOLD
TractorT68
May 15, 2022 01:11 PM
86Z
Members Camaros
Jun 29, 2019 02:46 PM
89FormulaLS
Members Firebirds
Nov 6, 2017 12:52 PM
KWIK84
Members Camaros
24
Nov 17, 2014 08:18 AM
fultimekilla
Canadian Region
Sep 9, 2012 12:19 AM
