[PA] Kmember, a arms, rear end
Old Sep 2, 2023 | 04:09 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
After life getting in the way too many times I am abandoning my project. Suspension installed has never seen the road. Only to do the rear end swap and get it rolling again. Parts NIB (new in box) or installed on car and are as follows. Located near Stroudsburg, PA.
  • BMR-KM008R K-member w/LS1 motor mounts, factory mounts. ($550) NIB
  • BMR-AA008R A-arms, lower, DOM, non-adj, poly bushings and spring pocket ($450) NIB
  • BMR-RH010 Control arm hardware kit front lower only ($10) NIB
  • 23790B Founders Performance 1982-2002 On-car Adjustable Panhard Bar w/Poly Bushings ($50) installed.
  • 24215B Founders Performance 1982-1992 Camber/Caster Plates ($150) NIB
  • 23881B Lower Control Arm Relocation Brackets ($40) NIB
  • Inline Tube SS brake line kit for rear disc ($150) NIB
  • Eibach Pro Kit Springs 3801.140 ($200) Rears installed Front NIB
  • Koni Yellows Front Struts Sport Series 8741-1030SPORT ($500) NIB
  • Koni Yellows Rear Shock Sport Series 30-1265SPORT ($200) installed.
  • JEGS WELDED D/S LOOP 82-02 CAM ($30) NIB
  • JEGS 550-40097 Adjustable Torque Arm 82-99 F-Body ($291.99) NIB
  • moser 9" 4:10 gears tru trac 31 spline 4 channel F-Body 1982-2002 5k miles ($2000) installed.
  • Racetronix GSS294M 255L/Hr Fuel Pump and FPWH-005 FL98 Fuel Pump Wiring Harness ($120) installed but never saw fuel.
  • Moog Front end Rebuild
  • NIB ($200)
Old Sep 2, 2023 | 04:17 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Suspension parts
Pics?
Old Sep 2, 2023 | 04:27 PM
DJ Delsym's Avatar
Car: 86 Iroc
Originally Posted by topduarte
Pics?
What parts would you like pics of? NIB parts are still in the boxes and installed parts still on the car.
Old Sep 2, 2023 | 06:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Kmember, a arms, rear end
Is the 9" a 3rdgen width or 4thgen? With the abs mentioned, im guessing 4th gen width ?
Old Sep 2, 2023 | 06:11 PM
DJ Delsym's Avatar
Car: 86 Iroc
Correct. Barely noticeable though.
Old Sep 2, 2023 | 07:08 PM
BOOBYE's Avatar
Hi,
Attach parts are new in the box and never been installed if so I will take them
please send me payment info shipping to 92583
Thanks.
Old Sep 2, 2023 | 07:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Where are you located?
Old Sep 2, 2023 | 07:41 PM
DJ Delsym's Avatar
Car: 86 Iroc
Near stroudsburg, pa.
Old Sep 3, 2023 | 06:56 AM
Nutro's Avatar
PM sent
Old Sep 6, 2023 | 05:57 PM
RoadRace's Avatar
Car: 85 IROC
Engine: 5.7
Axle/Gears: 4.11 torsen, 4th gen rear
Hi - are brakes included on the 9”? Which ones? 1310 yoke? Daytona pinion support or stock? Does it have OEM sway bar locating tabs?
thanks
Old Sep 6, 2023 | 06:45 PM
DJ Delsym's Avatar
Car: 86 Iroc
1350 yoke, not sure in the Daytona pinion support but that’s common with the big ujoint and it comes with fourth gen brakes.
Sway bar mounts with u bolts and it comes with the sway bar and control arms.
Using stock rear wheels with nearly new bfgoodrich tires, can include or take off.
Old Sep 6, 2023 | 06:58 PM
DJ Delsym's Avatar
Car: 86 Iroc
Old Oct 4, 2023 | 01:30 PM
DJ Delsym's Avatar
Car: 86 Iroc
Bump
DJ Delsym
LSX and LTX Parts
Sep 2, 2023 03:48 PM
mjshort
Nov 20, 2006 08:58 PM
malaka
Mar 4, 2005 07:08 PM
87CamaroMan
Sep 26, 2003 01:01 PM
GoldenSwordZ28
Apr 29, 2002 06:07 PM
