Need AC lines and maybe compressor
Looking for good condition AC lines for the 2.8/3.1 setup that go from the accumulator the compressor. Possibly the compressor too if it is in know good condition.
I am assuming that the v8 and v6 lines and maybe compressor are different but if anyone know for sure to clarify that would help, as it would open my options.
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
I have the line $25 plus shipping. Its on a non running parts car so I have no way to test them but they look good. The compressor I know is bad. LMK
could you post or send me a couple pics (eddiejr@rogers.com)? So you are referring about the lines that go from the compressor all the way around to the accumulator? What year is it off of?
thanks.
thanks.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got one ---->
This set-up is from an 88 coupe with a 2.8 MPFI engine. $60 + shipping. I can't promise the compressor works because the AC and smog pump was bypassed by a shorter belt when I bought the car.
Please let me know one way or the other ASAP.... If you don't buy it I'm mounting it on my 87 2.8 right away !!!!!!!
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
v6 A/C lines
I have a set of A/Clines from a 2.8 89 firebird. The lines came from a running car. ASking 15.00 plus shipping
ok, lines taken care of, thanks guys.
Just out of curiosity, what is the model number on the compressor? Was it V-belt or serp?
The 88 Was a serpentine set-up.
The numbers on the compressor are: ' 1131635 '
It's the last 3 digits of the model # : 635
The Compressor on my 91 3.1 appears to be exactly the same style as the compressor from the 88; but the model number is different.
The numbers on the 91 3.1 compressor are: 1131743
I've also got several compressors from various V-belt car as well with compressor numbers: 1131198 & 1131382
I do not KNOW why the numbers are different from compressor to compressor but would assume that it has to do with hose routing, plugs/connectors, & pullys.
