I need a 700r tail housing for iroc
Old Jun 20, 2006 | 03:00 PM
Camaroman P's Avatar
Car: 1998 Z28
Engine: 350 lt1 sued up
Transmission: 460le
Hi does anyone have a 700r4 tail housing for iroc for a willing to trade for corvette tail housing or pay money it does notmatter but need one asap
Old Jun 20, 2006 | 05:53 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I have one for $40 shipped, its from a 92 RS with 700R4 Trans.......jt
Old Jun 20, 2006 | 08:11 PM
Car: 1998 Z28
Transmission: 460le
sold tail housing and output shaft
I also need the output shaft to if you have it I would also need more parts if you have alot of camaro parts do you have a tpi
Old Jun 20, 2006 | 10:27 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Output shaft? Is this the shaft coming out the end of the trans through the tailhousing? If so I wouldnt even begin to know how to remove it. I usually stay clear of messing with auto transmissions other than removing torque converters, fluid pans, and tailhousings. I may be picking up a TPI car this week though but wont know until tomorrow sometime.........jt
Old Jun 20, 2006 | 10:45 PM
Car: 1998 Z28
Transmission: 460le
out put shaft
yes it is that man if you can get it I will send you the one for the corvette instead please man I need it
Old Jun 20, 2006 | 11:00 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Do you mean the driveshaft which goes from the transmission to the rear end? the only way to remove the actual output shaft of the transmission is the completley dissasemble it. now, if you meant the driveshaft, thats a different story all together.
Old Jun 21, 2006 | 09:25 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I know someone who rebuilds trannies so i'm sure he could remove it in a matter of minutes. what are you looking to spend on it? I could probably do $120 shipped for the shaft and tailhousing depending on if he will remove it for me at a minimal charge...........jt
$35 Tailhousing
$50 Shaft
$15 S/H
$20 for the guy to remove the shaft if he agrees.
$120 total.
Old Jun 21, 2006 | 09:35 AM
Car: 1998 Z28
Transmission: 460le
sounds good
shoot me a phone number it sounds good just let me know when he finishes the job so I can pay
Old Jun 21, 2006 | 12:48 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I talked to him earlier, he said he can have it completely dismantled in a matter of minutes. Next problem is, trans is still in the car and after being burned several times in the past it wont be pulled out until payment is recieved(not looking to waist my time on it then you find the parts local or find them from someone else). Once i get the payment I can have the parts shipped within 24 hrs. Paypal is jtmiller92@alltel.net or you can send a money order to the following address. You can check my user name in the feedback section if your worried about getting burned..........jt
Jeremy Miller
117 Briarwood Dr
Nicholasville, KY 40356
(859)338-7351
Old Jun 22, 2006 | 09:17 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Did you change your mind or find the parts elsewhere?
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 19, 2015 01:36 PM
mustangman65_79
Aug 11, 2015 03:17 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
