081 or 113 heads
Old Jan 18, 2007 | 04:53 PM
riotpolice75's Avatar
081 or 113 heads
after a set of either 113 or 081 casting heads. hit me up if you have either
Old Jan 19, 2007 | 08:53 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Im 99.99% sure I have a set of 081 heads at my shop... Ill look at them tonight and get back to ya... Ill make ya a great deal just so I can get them out of the shop...
Old Jan 22, 2007 | 04:36 PM
it was a bust with kenwood. he had a set of 083's. anyone else?
Old Jan 22, 2007 | 09:14 PM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
I have 2 sets of cast iron heads that i am in the process of getting rebuilt, one set has centerbolt valve cobers and the other has 4 corner valve cover bolts, both sets are 1.94/1.5 valve heads. I would have to take a trip to the shop to check the casting numbers, dont know if you would even be interested in them.
~Nick~
Old Jan 28, 2007 | 09:42 AM
bump
Old Jan 30, 2007 | 11:38 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
981 duel springs, .600 lift clearance, ARP screw in studs, 10deg locks, stainless exhaust valves, brand new valve job 14deg back cut on all... all comp cams parts... porting done 1205 gasket match, smoothed out all imperfections, bowl cleaned out...bumps removed from floor and ceiling...
cumbustion chambers untouched.
just not enough head for the cc306 cam and HSR intake.... going bigger
pm if interested
Old Feb 5, 2007 | 08:27 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I just listed a set of stock #113's
Old Feb 11, 2007 | 03:47 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I have a set of 081's need rebuilt 50$ + Shipping from OK, LMK if interested
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
