Block's Or Engines And 383's
Im looking for either a 350 or i would prefer a 400 block. Or a 350/400 block with some things included (heads intake etc...) but no where near a complete motor. Would prefer ones needing a rebuild but it doesnt have too. Really looking for a 400 but will take a 350. Also looking for 383 parts ( cranks/rods/pistons) Also looking for a set of aftermarket heads iron or aluminum doesnt matter is they are bare or not. Prefer Bare or in need of rebuild.
Let me know what you guys got. Looking Around the NY/CT/NJ/PA Area because I live on Long Island.
Thanks Alot,
Thanks Alot,
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Ill have to find out. My boss owns a machine shop and I know we have a couple of 400s laying around. Ill let you know tomarrow.....
\Im right in orange county, zip 10940.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
I can hook you up with a complete 350 4 bolt main in need of a freshining up. I also have a brand new aftermarket stroker crank that will fit in it if interested. I'm on the South Shore of LI in Patchogue. LMK Dean
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
I got a high nickel 4 bolt main 350 block out of a 71 chevelle sitting in dry storage I wouldn't mind getting rid of, Its got a set of factory 72cc heads (garbage), starter, flywheel, and im pretty sure I got an edelbrock manifold N.I.B. to go with it (ill have to check). $$200 the motor was running when it was pulled. PM me if your interested.
Car: 92 rs
Engine: 305 soon to be 350
Transmission: th700r4
I have your block
I've got a pre-86'
I've got a pre-86' 350 small block ~$300 zip-07728 I'm in new jersey.
In good shape, good for rebuilding, good foundation for your build up.
Car: 1991 RS/ 2006 Charger R/T SRT-8
Engine: 383 4bbl / 6.1 liter HEMI
Transmission: TCI 700R4
Axle/Gears: 3.42 posi
350
I have a 350 short block #010 stock rods and pistons all checked out but needing a cleaning, #3701 Edelbrock intake, #336 76cc mildly ported heads and springs good to .520 lift 1.94/1.5 valves and I'll throw in a balancer for $225 I'm in southern Ky
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
i have a 350 block or a 406 short block short block has gm pink rods arp2000 bolst studded main speed pro forged pistons and only 3000 miles on it
