Wanted: 350 TPI Complete Engine
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
I need a 350 TPI engine, as the title says. Has to have a 1 piece rear seal and the centerbolt style heads. If it isn't a far reach maybe one from an 89 car. I don't need the tpi system, as I already have it and it would also save me some money. THANKS
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
Re: Wanted: 350 TPI Complete Engine
I have a 86 up 355ci with less then 10mi, Rebuilt center bolt heads 193 castings new from top to bottom, has water, power steering pumps, And alternator, FI block one peice rear main seal. out of car and ready to gointo another car.
Car: 1989 IROC-Z
Transmission: t56
Axle/Gears: 410
i have a 350 tpi with 400+ hp. it has the holley stealth ram intake and aluminum heads. located in felton DE.
Whats your price? I found a local shop that can set me up with an engine that they rebuilt for $700, I'll probably go with that option, but if you can beat that be my guest. Most likely you won't because it sounds like you got some money in that thing, but it can't hurt to ask.
Terrell351
Jun 13, 2021 01:13 PM
