I need
Old Jun 20, 2007 | 10:09 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
I need
I need an accelerator pedal set up for a fuel injection engine. My carb pedal does not actuate the throttle body fully now that I have converted to fuel injection.
thank you
jeff
Old Jun 20, 2007 | 10:19 PM
helrazor's Avatar
Car: 91 camaro rs,92 camaro b4c,1983 cam
Engine: 305 tbi Soon To be 500hp 383,l98,ca
Transmission: 700r4,700r4,turbo 400
Re: I need
I have one off a 91 camaro rs with 305 tb what stuff do you need exactly
Old Jun 20, 2007 | 10:20 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Re: I need
thank you
jeff
you need the pedal or the throttle cable?...
Old Jun 21, 2007 | 09:11 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
Re: I need
I believe you need the Cable as that the Pedals are the same for Carb or Fuel Injection. I do carry Throttle Cables. They run $10.00 plus shipping and handling. If you have any questions or other needs we can be reached at (818) 700-7970.
Thank you,
Thomas R. ***
(818) 700-7970
www.houseofcamaro.com
Old Jun 21, 2007 | 09:25 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: I need
Correct on both counts, Tom.
jj,
You only need the cable and house of camaros will fix you up. I bought my cable from them and it works great.
Old Jun 21, 2007 | 05:29 PM
jjlabinski's Avatar
Engine: shinny 350
Re: I need
I have a brand new cable from lokar. I believe the carb pedal assy is not compatible with the tpi set up. my cable is hooked up to the throttle body and the pedal but when the pedal is fully depressed the throttle body only opens half way. So it is my belief that the pedal assy on a tpi has a different angle on the pedal arm allowing a different amount of travel of cable for the same or relatively close distance of travel of the foot portion of the pedal assy.
someone please correct me if I am wrong.
thx
jeff
Old Jun 22, 2007 | 07:25 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: I need
I am here to correct you cause you are wrong. I just did this exact swap last year. You just need to get a stock tpi cable. sometimes aftermaket cables don't really work so well. My throttle was wide open when I did my swap. You need your cable to be tight to. don't have too much slack in it. That too will cause your throttle not to be wide open.
Old Jun 22, 2007 | 03:41 PM
jjlabinski's Avatar
Engine: shinny 350
Re: I need
I will re check the root cause
thank you
Old Jun 22, 2007 | 07:21 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: I need
i tried the lokar cable for about 5 days. then i ordered a brand new factory one. this is why i haven't ordered their e-brake cables for my 4th gen rear swap.
Old Jun 22, 2007 | 09:18 PM
jjlabinski's Avatar
Engine: shinny 350
Re: I need
87 jeff what was your assesment of the lokar setup?
did it produce the same condition I am experiencing?
thx
jeff
Old Jun 23, 2007 | 09:26 AM
87zjeff's Avatar
Re: I need
yeah....with the lokar set-up, i couldn't get close to WOT. seemed like the housing wanted to flex and not support the cable.
Old Jun 25, 2007 | 07:00 PM
jjlabinski's Avatar
Engine: shinny 350
Re: I need
I really dont want to lose the look of my engine by replacing the lokar cable for this is a show car. I guess I will have to develop something to multiply the travel with the setup I have.
thx
jeff
