TPI Setup
TPI Setup
I am looking for a TPI setup for my 92 350. I need everything from the intake to the throttle body and the wiring and ecm. Would prefer a whole setup but will consider buying pieces if the price is right.
also is there a difference between the setup on a 305 and a 350?
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: TPI Setup
I know you got shafted by a guy on here .... I have a "730" speed density emc with a L-98 chip with VATS delete for 40.00 shipped
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: TPI Setup
I might be able to get you an intake base for 87 and up. Would need to get runners and plennum with the hardware and gaskets. Let me know what you are willing to spend, I will see what the yard wants for it and see what kind of deal we can work out.
Re: TPI Setup
I have a passenger side runner that you can have for free if you pay shipping.
Come'on guys this poor dude got shafted by a seller on here lets help him out!
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Re: TPI Setup
Ray
Re: TPI Setup
man u guys have been great. I really appreciate everyone helping me out after what happened earlier. I am hopin to find a whole set up so that i know that everyhting will work together. also I am wanting to pick it up myself. I am a little weary after sendin money last time. So if you could post locations too. I got alot of college buddies that travel so we got alot of options.
Re: TPI Setup
I'm in Phoenix. Also I have a TPI harness for Mass Air Flow system with computer. Got the computer for $50 a while ago, just put TPI in my car and bought a new ECM for it. The extra ECM can be tested when I'm sure my car is running the way it should. I also have a Hypertech PROM from an 87 TA with 350 TPI. The harness has link lead to dual fans. The harness also needs a few repairs. If you are interested, I can make the repairs for you and take all the guess work out of it. Willing to help out with cost, but can't give it for free. I will accept reasonable offers (name your price and most likely I will consider it - but from you only unless otherwise noted later). I'm looking to lessen the clutter in my garage soon, so if anyone is in Phoenix or surrounding cities, I have extra parts to get rid of. Let me know what you need.
Chris
Chris
Re: TPI Setup
I also have a free plastic plenum extension you can have.
camaro drail .... be hard to find a cheap 90-92 speed density harness. You could get a TBI harness and convert it to run a TPI system. The a tech article about is here.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Re: TPI Setup
I have a SD wiring harness from a 90 Formula, but it was converted to fit a 91... I was looking to get 140 plus shipping for it. If you are interested, let me know.
Thanks,
-Tim-
Thanks,
-Tim-
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: TPI Setup
I got a complete setup from an 86 maf only has 500 miles on it. harness pcm and all I also have a vortec base with 500 miles on it. let me know. I have new k&n filters in the y intake. I'll take $450 for everything
Car: 92 Camaro RS
Engine: 305 TBI
Re: TPI Setup
I have a complete TBI to TPI swap. I bought it on this forum a while back for my 92 RS but I just don't have the time to make the swap. This is the speed density setup with 730ECM from a 91 350 Z28. I have all the induction piping including K&N filters, fuel rail, injectors, adjustable fuel pressure regulator, TB airfoil and TPIS plate. I also bought the aluminum distributor cover so it could be polished to match the intake. I also have the wiring harness and I should still have the diagrams as well. Everything has been media blasted, I just never got around to powdercoating or painting anything. I had started to polish out the upper plenum but never finsihed. The EGR block off plates and thermo housing were powder coated. I have all the bolts to assemble the TPI as well.
Here are some photos:
http://www.ironman24.carolinafbodyclub.com/temp/TPI/
Let me know if you are interested.
Sanjay
Aug 12, 2015 03:41 PM
