looking to loose some weight in my 88 formula
Old Mar 18, 2008 | 11:42 AM
scaryjerry's Avatar
Transmission: t-5
just as it says. car weights 3690 on a quarter tank of gas without me in it! any info to lighten it up or some parts ppl have laying around.(already done ac delete) car is fully loaded.... want to keep the stock look for the most part. send me pms, thanks.
hood
fiberglass stock looking wing
ligh weight carpet
fiberglass doors?
Old Mar 18, 2008 | 12:17 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Re: looking to loose some weight in my 88 formula
Where did you weigh that? Cause its way off! (its LOSE---not LOOSE (loose fitting ie) BTW)
My car has a/c, T-tops, pw, pdl, pm, cruise--weighed 3410.
I do have the fiberglass wing and alum heads but that does not equal 200lbs (my STB, SFC and wonder bar add weight)
Go for some alum heads!
Old Mar 18, 2008 | 12:35 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
aluminum heads (removes about 50lbs)
btw, my 86 Trans Am with the A/C removed weighed in at 3380.
Old Mar 18, 2008 | 01:14 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
This is from the Technical Articles section of this website....
https://www.thirdgen.org/sheddingpounds
I might add that you can save weight by adding a manual box from Flaming River. The aluminum one can save upto 40 lbs after ditching the entire power steering set-up. I believe the aluminum box is only 13.5 lbs. Going to a tubular front subframe loses another 40 lbs or more.
Old Mar 18, 2008 | 08:37 PM
scaryjerry's Avatar
Transmission: t-5
I have aluminum heads on the car when i weighed it.
Old Mar 18, 2008 | 09:31 PM
Zepher's Avatar
I would get your car re-weighed again, just to verify that it is that heavy.
My 86 was fully loaded with powered leather seats and a small stereo system.
Old Mar 18, 2008 | 09:32 PM
avro206's Avatar
Car: 89 Formula
that scales is broken. I have dozens of pulblsied weights on 3rd gens.....none are 3600+ lbs
if you can find another scale.....my car sounds close to yours for options--we both have alum heads...and I had mre then 1/4 tank of gas too. Something does not add up and it points to the scale.
Old Apr 4, 2008 | 07:36 PM
11SECRS's Avatar
Want a title? Post!
I put tubular front crossmember, lower control arms,removed power steering gear box (replaced with manual rack & pinion) power steering pump etc, dropped between 150-200 pounds
Old Apr 9, 2008 | 01:11 AM
darkcrave's Avatar
vert?
83 Crossfire TA
Jan 3, 2016 01:26 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
90formulaVortec
Sep 8, 2015 12:42 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
90formulaVortec
Sep 7, 2015 06:54 PM
