wtb 400 small block
Old May 19, 2008 | 07:45 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
wtb 400 small block
im looking for a 400 short block with no cracks, or major imperfections preferably a 4 bolt main but will consider 2 bolt if in good condition pm me, thanks
Old May 20, 2008 | 10:14 AM
SteelTownMadDog's Avatar
Re: wtb 400 small block
Just an FYI - The 2-bolt 400 blocks are stronger than the 4 bolts.
Old May 20, 2008 | 11:43 AM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
another fyi: try posting this in the wanted forum, not the for sale forum
Old May 20, 2008 | 01:04 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
https://www.thirdgen.org/forums/engi...shop-misc.html
heres one
Old May 20, 2008 | 06:58 PM
jimmy2s83's Avatar
Car: 1992 Pontiac Firebird
Engine: 454 BBC
Transmission: TH400
Got a 400 posted on here. Not sure if its a 2 or 4 bolt main though.
Its already built up to 455hp and 490tq.
Asking $1300 but open to offers
Located in Hagerstown IN 47346
Old May 26, 2008 | 07:45 PM
what makes the 2 bolts stronger ???
Old May 26, 2008 | 08:07 PM
camarokracker's Avatar
Car: 86 Camaro Sport Coupe
Engine: 377 sbc
Transmission: WC T-5
Axle/Gears: 3:70 Ford 9" Rear
Replied to your pm... and i can answer your question... The thought is that the 4 bolts go straight down and all the really do is remove material from the block. Is this true.. dunno.. I am freinds with the owners of a few high performance shops around here and this debate has gone on for as long as i can remember even with the 350 blocks.. For the ultimate answer there is only 2, But a 2 bolt block and have it drilled for 4 bolt splayed main caps or call a company like world industries. I hope this ehlps a bit...
Old May 27, 2008 | 02:27 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Don't turn down a four bolt main block if it comes your way. Use main studs instead of main bolts and you'll be fine. With main bolts, most of the holding clamp pressure is on the main webs. With main studs, the pressure is equally distributed between the caps and the web. If your block is going to be line honed or bored, tell your machinist that you are going to use main studs so he/she can use them in the machining process.
Old May 27, 2008 | 03:18 PM
Engine: 377 sbc
Also remeber that the 400 4 bolt was only made for a couple of years.. so there are far more 2 bolts out there.. both are good for moderate street power... just my .02 from experience..
Old May 28, 2008 | 06:14 PM
thanks alot to both of you that information is very helpful
Old May 28, 2008 | 10:06 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
I have a complete 400 SB engine that has been in storage in a garage for probably 20 years, I would consider it a core since it has sat so long. $350 complete NY zip 12538.
Old May 30, 2008 | 07:33 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
I have a block and everything to complete it in stock
Located north of Philadelphia.
Josh
215-783-4645
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
