WTB: Misc Engine & Suspension Parts
Old Nov 11, 2008 | 12:25 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Aluminum Fast Burn Heads
140 Amp Alternator
Performer RPM Intake
750-800 cfm Carb
Distributor
Aluminum Radiatior (Auto Trans)
Dual Electric Fans
Oil Cooler
Air Cleaner
Valve Covers
Edelbrock TBI Strut Tower Brace
Grant Steering Wheel
Rear LCA Relocation Brackets
I may be interested in other parts, just let me know what you have.
Old Nov 11, 2008 | 02:43 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: WTB: Misc Engine & Suspension Parts
I can help you out with a few of your needs. I have the following:
Edelbrock STB
Dual Electric Fans
Chrome Valve Covers in both center mount and conventional
Older Grant 13" Steering Wheel...great condition
How is the rest of your suspension. Tell me if you can use anything on these links.
https://www.thirdgen.org/forums/engi...uspension.html
https://www.thirdgen.org/forums/engi...-2-8-4bbl.html
PM me with a list and I'll give you a good deal.
Old Nov 11, 2008 | 03:35 PM
Stippy17's Avatar
PM Sent
Old Nov 11, 2008 | 04:13 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
looking for control arms or panhard bar Ive got brand new lakewood control arms and a barely used spoohn panhard bar
Old Nov 11, 2008 | 04:26 PM
Stippy17's Avatar
I already have a UMI Panhard Bar & Lower Control Arms, do you have Upper Control Arms?
Old Nov 11, 2008 | 08:49 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
I have a stock gm vac advance stand alone dizzy...$50 + shipping, comes with new cap, rotor, coil (HEI)
Old Nov 12, 2008 | 11:16 AM
wesilva's Avatar
Transmission: 200R4
3rd Gens are three link suspensions. What would be the upper control arms in a four link are controlled by the torque arm in 3rd gens...and 4th gens, for that matter. So to upgrade from stock, you need a high performance torque arm. The best, in my opinion, is Spohn. It's an integrated system that uses a special transmission crossmember to mount the high performance torque arm. I happen to have the transmission crossmember but not the torque arm. Look at the Spohn website.
Old Nov 12, 2008 | 06:05 PM
Stippy17's Avatar
I have already bought a UMI TH400 Crossmember & Torque Arm, sorry.
Old Nov 12, 2008 | 07:05 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I have a powermaster 140amp XS volt chrome Alternator
Old Nov 13, 2008 | 08:37 AM
battz86's Avatar
Have an Edelbrock Performer Rpm ,and a Barry Grant 750 vac. sec. if interested.
Old Nov 13, 2008 | 10:46 AM
Stippy17's Avatar
How much? Not very interested in Chrome, but for the right price I might consider.
Interested in the Intake, and maybe the Carb. Pics & Prices?
Old Nov 13, 2008 | 05:51 PM
Darrin's Avatar
Car: 86 Iroc-z
Engine: Lt1
i have a aluminum radiator with oil cooler lines (for auto trans) bought it for my old 350tpi setup and did engine swap so no use for it.. its only got 2k miles on it. basically brand new, name a price..
Old Nov 14, 2008 | 08:50 AM
battz86's Avatar
https://www.thirdgen.org/forums/engi...tml?highlight=
Old Nov 14, 2008 | 03:01 PM
Stippy17's Avatar
Which brand is the radiator? How much would you like to get out of it?
Other PMs Sent.
Old Nov 15, 2008 | 10:42 AM
Darrin's Avatar
Car: 86 Iroc-z
Engine: Lt1
its basically an oem replacement. its aluminum and plastic. very light too. i dont remember what brand.. i can check my garage later. ill take $75 for it.
Old Nov 15, 2008 | 12:22 PM
Stippy17's Avatar
Alright find out and get back to me.
Old Nov 17, 2008 | 02:08 AM
Darrin's Avatar
Car: 86 Iroc-z
Engine: Lt1
i actually cant find a brand on the radiator. it just says made in canada. its like a couple months old and hardly used. i have a pic of it so you can see for yourself. i paid $175 for it and like i said ill take $75. thanks, darrin
Attached Thumbnails WTB: Misc Engine & Suspension Parts-1117080301.jpg   WTB: Misc Engine & Suspension Parts-1117080301a.jpg
Old Nov 17, 2008 | 03:36 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I've got a CS144 that fits a V6 (100* Bolt spacing, versus the 180* you need to adapt to factory serpentine). :/ Seems that you're upping to a V8 though. If you're using the factory serpentine, then it won't work, but if you're fabbing something up, it works fine.
Old Nov 17, 2008 | 10:23 AM
CaysE's Avatar
I have a pair of new upper strut mounts with new bearings and Spohn bottom retainers, if you need them. Only looking for $100.
Old Nov 17, 2008 | 10:57 AM
Stippy17's Avatar
May be interested, pics?
Old Nov 17, 2008 | 06:58 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I've got a Powermaster 140amp alt. I'd like to get $130 shipped for and a Mallory 85 series dist. with a Accel coil I'd like $100 shipped for.
Also have March two-piece underdrive pulleys for non-serpentine accessories, $50 shipped.
Old Nov 17, 2008 | 07:15 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
I have proform valvecovers, There chrome and say "chevrolet" in black and have a bowtie in red. There perimeter bolt, 40 bucks shipped to lower 48 sound good?
Old Nov 18, 2008 | 11:00 AM
Stippy17's Avatar
Interested in all, can I see pics?
My email is bobby_stipkovic@comcast.net if you want to send them that way.
Old Nov 18, 2008 | 12:57 PM
91txta's Avatar
Want a title? Post!
Car: 91 Trans am
Axle/Gears: 3.42:1
I have a set or 113 d port heads removed from a 1989 corvette, also a set of magnesium valve covers, and a high torque starter all removed from the corvette. Also have new in box crane cam and summit lifters hydraulic flat tappet, and 1.6 self aligning roller tip rockers. heads 350.00, valve covers 75.00, starter 25.00, cam and lifters 75.00, rockers 25.00, plus shipping on any parts you want. All prices negotiable
Old Nov 18, 2008 | 07:55 PM
Duts87ss's Avatar
I'll get you the pics on Friday. My week days are too busy and I get home too late to take any right now. I may have a pic of the alt. and dist. while it was in the car though.
Old Nov 18, 2008 | 08:35 PM
Stippy17's Avatar
Let me buy the few things I plan on buying, and see how much money I have left til my next paycheck.
Ill take the Alternator, but probably pass on the Distributor for now because a lack of funds. PM me your Paypal username if you have one.
Updated List:
GM Performance Fast Burn Heads
Valve Covers
Air Cleaner
Distributor
Wire Looms
MSD Ignition
Possibly Headers
Edelbrock Strut Tower Brace (TBI)
Now after I buy the Intake, Carb, Alternator, and possibly a few little things Ill be tight on funds for a week or two, but Ill still be looking for parts for when I have the money.
Old Nov 18, 2008 | 08:53 PM
Duts87ss's Avatar
PM Sent. I just noticed that you are looking for an air cleaner also. I'll go $50 shipped when you're ready.
Old Nov 19, 2008 | 09:55 AM
CaysE's Avatar
Here you go... they were mounted to the car but never even put on the ground. Still new:
Old Nov 19, 2008 | 11:39 PM
Stippy17's Avatar
Let me hold off on the mounts for now, but I know you have them if I decide I need them/can afford them.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 5, 2015 11:57 PM
