WTB > TBI (CT)
Old Nov 23, 2008 | 10:19 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
WTB > TBI (CT)
Info: I was told the 350 tbi is bigger and allows more air flow being sucked into the intake. Currently I have a 305 tbi (in my 1989 camaro rs) So if i'm wrong from what I heard; would anyone correct me please?
Looking To Buy:
350 TBI (my year or something that would fit)
regards,
Timinsk
Old Nov 23, 2008 | 11:15 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
Re: WTB > TBI (CT)
go to a junk yard
buy one off a 350
buy the rebuild kit for $22
then do the ultamite TBI mods
https://www.thirdgen.org/ultimatetbi
https://www.thirdgen.org/ultimatetbi2
only thing different is youll need a tps pig tail and youll have to splice 3 wires
you also might lose cruise control
Old Nov 23, 2008 | 11:35 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: WTB > TBI (CT)
Should I look for my same car for the 350? or does it not matter?
Old Nov 23, 2008 | 11:52 AM
Madcrazy's Avatar
Car: '91 Formula
Engine: 5.0 TBI
Re: WTB > TBI (CT)
I have a holley unit with maybe 200 miles on it. pm me if interested.
Old Nov 23, 2008 | 12:15 PM
Chezoom's Avatar
Engine: LO3, LG4
Re: WTB > TBI (CT)
mine is off a 87' 350
and i have a 91' 305 so i dont think it matters to much
Old Nov 23, 2008 | 01:35 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: WTB > TBI (CT)
oh ok; how much do they normally go for at a junkyard?
Old Nov 24, 2008 | 03:38 PM
Chezoom's Avatar
Engine: LO3, LG4
Re: WTB > TBI (CT)
i dont know that, i got mine from my auto tech teacher
he just gave it to me
Old Nov 24, 2008 | 06:00 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: WTB > TBI (CT)
haha lucky :P
Old Nov 25, 2008 | 11:27 AM
R3500's Avatar
Re: WTB > TBI (CT)
Anybody know the numbers for the 350 TBI injectors? I have about a dozen of them (throttle bodies) from 4.3, 5.0 and 5.7 engines...but not sure which is which anymore. Can give you a deal after matching up the linkage arm patterns..the wiring is the same for all of them.
Timinsk:
FYI only, I have the "same motor" in my 1988 Chevy 1/2 ton 2WD pickup w/5sp manual. Got the motor out of a 1989 IROC Camaro with auto TBI (low mileage car with rusted towers). Engine was very clean inside, mic'd within specs so I just installed new rings, bearing and oil pump.
The engine runs great, great compression and is very dependable..BUT NO POWER OR SNAP! Installed a 350 throttle body, 350 MEMCAL and it still is gutless. Running straight exhaust through a glass pack..zero exhaust restriction!
With the engine running noticed that the lift on all 16 lifters is minimal. I just bought a 305 HO (roller) cam for it..which is computer compatible..but didn't put it in yet.
I'm sure it's the heads/cam combination...the cam is the easiest fix for now. There is a good deal on a 305 comp cam for sale in the engine parts for sale section right now.
Wouldn't waste time changing the throttle body without a better cam, air filter and exhaust...didn't do a thing for me.
Ed
Old Nov 25, 2008 | 06:09 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: WTB > TBI (CT)
hmm; thanks that actually helps a bit. I'm just thinking of getting the 350 and rounding out the upper trim around the cylinder holes
Old Nov 28, 2008 | 03:50 PM
Chezoom's Avatar
Engine: LO3, LG4
Re: WTB > TBI (CT)
Timinsk:
Ed
the 4.3 and 5.0 are 40lb injecters
5.7 are 50 lb injecters
http://tbichips.com/305mods.htm
i think the 350 truck injectors are different then car injectors
Old Nov 28, 2008 | 05:26 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: WTB > TBI (CT)
Oh wow that helps alot!!!!
Old Nov 28, 2008 | 05:55 PM
R3500's Avatar
Re: WTB > TBI (CT)
I would check the injector numbers for comparison first...really doubt that there is any significant (if any) difference between a car/truck 350 TB. I tried various car/truck TB combinations with virtually no performace changes. I bet if you check the lift on your cam..you will learn that it is minimal..throw in bad flow heads...you'll need more than extra raw fuel.
Old Nov 29, 2008 | 04:47 PM
the973camaroguy's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 2.77
Re: WTB > TBI (CT)
Looking To Buy:
regards,
Timinsk
i have one off a 93 chevy van im looking to sell for 45 obo
Old Nov 29, 2008 | 04:51 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: WTB > TBI (CT)
hm that helps now, i guess i wont be needing a different tb; thanks!
Old Nov 29, 2008 | 06:46 PM
Chezoom's Avatar
Engine: LO3, LG4
Re: WTB > TBI (CT)
you could put 350 injecters
ultamite tbi mods 1 and 2
and a spacer and youll be good to go
Old Nov 29, 2008 | 08:33 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: WTB > TBI (CT)
Thats what my ideal goal is now; just get the injectors and try some of the guides, and what kind of spacer would be recommended? I'm looking into open air element.
Old Nov 29, 2008 | 09:45 PM
Chezoom's Avatar
Engine: LO3, LG4
Re: WTB > TBI (CT)
dont go to big on the injecters yet, just a waste of gas imo
spacer, i dont know, im in the market to for one
open element is good to have
Old Nov 30, 2008 | 08:06 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: WTB > TBI (CT)
well i was just going to go for the 350 injectors (55lb/hr)
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
