ps pump bracket , alt bracket and pulleys no ac needed
Old Dec 14, 2008 | 05:02 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
hey guys does anyone have the powersteering bracket, alt bracket and pulleys for a v8 camaro. i dont want anything fancy just stock brackets and puylleys. for long style wp. thanks in advance
Old Dec 16, 2008 | 06:38 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: ps pump bracket , alt bracket and pulleys no ac needed
are you looking for serp brackets or V belt? if v belt I think I have all of it.
Old Dec 16, 2008 | 07:53 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
id use either one. v belt is ok i just need all of it. ps braket alt bracket and pulleys. long water pump
Old Dec 16, 2008 | 08:17 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Columbus, Ga.?
I have an extra serpentine setup.
Why do you keep saying long water pump?
Are the 3rd gen V8 WPs considered long or short?
Old Dec 16, 2008 | 09:20 PM
jstoltz's Avatar
all of them are long just saying that the old v belt stuff won't work with his pump. I have all and brackets and the power steering pump. Pretty sure anyway $50 and shipping if you want all of it.
Old Dec 17, 2008 | 05:56 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
let me check the local junk yard first. i might find a little better than 50 for two brackets and the pulleys. i do not need a ac bracket. but im intersted. ill go to the local junkyards tomorow. and ill let you know by the end of the day. !
how much for the serp setup.
Last edited by mattsv8_03; Dec 17, 2008 at 05:58 PM. Reason: Automerged Doublepost
Old Dec 18, 2008 | 06:50 AM
jstoltz's Avatar
I was including the power steering pump also I have the alternator that I used with it but I tore it apart and semi polished it. could use more polishing. and put back together. Well worth $50 but it's up to you.
Old Dec 24, 2008 | 02:55 PM
phntomfx's Avatar
i have the entire serp set up, and i also have an a/c eliminator bracket with the pulley, i have everything except the crank pulley, i need it gone so i will sell everything for $150, i'll throw in everything i have a/c pump, all brackets, p/s pump, alt, everything i got!!
Old Dec 25, 2008 | 09:26 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
how far away is tiffin from columbus oh.
i might just drive to get them.
IROCZ1989
Jan 24, 2016 03:55 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
