WTT: tpi intakes i need 90-92 map...have 87 MAF
Car: 1987 Z28
Engine: LG4
Hi all, i bought my basket case 92 t/a to find out the included tpi intake assembly was wrong one and was meant for a 87 tpi car. i need the upper plenum and throttle body for a MAP car. I found out the vacuum routing and such is in correct for my setup. Also, it has no provisions for the MAT
i have a set of runners and base plate that were spares from a 89 vette so i dont have to worry about the base plate supposedly
Car: 1987 Z28
Engine: LG4
Re: WTT: tpi intakes i need 90-92 map...have 87 MAF
BUMP i need upper plenum and throttle body(maybe just the lower plate that the IAC goes into)
i cant find a 730 ecm anywhere local
There is a 730 ECM and ANJF MEMCAL on ebay right now:
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
I'm not connected to it...just FYI.
Car: 1987 Z28
Engine: LG4
still looking for 90-92 Speed density parts
(looks like im getting a computer)
needing:
all bolts
sensors
intake parts
fuel rails(non cold start)
24lb injectors
front accesory brackets(bog aluminum ones)
alternator
air pump
delete pulleys
I do have Edelbrock tes headers for a dual cat car(n10 code) that are in really good shape to trade. Guy bought them and broke them in on his race motor and burnt coating off......
has a home made y-pipe.
If local i have a BRAND NEW dynomax super turbo cat-back for dual cat car also for trade(so new and nice it has the stickers on tail pipes still
needing:
all bolts
sensors
intake parts
24lb injectors
alternator
air pump
delete pulleys
) Thread Starter
Car: 1987 Z28
Engine: LG4
no body has old 91-92 MAP intake parts laying around?
re-doing my car the right way sucks......cant find teh parts for it
Car: 1987 Z28
Engine: LG4
i got a 730 ECM Thanks to Ted gerland
still looking for
90-92 MAP plenum
24# injectors(lt1 stock are fine)
fuel rail
throttle body
sonsors
still looking for
90-92 MAP plenum
fuel rail
throttle body
sonsors
1992rs/ss
Jan 31, 2025 05:10 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
