Looking for Vortec Heads
Old Dec 23, 2008 | 02:17 PM
rdaggett's Avatar
I have a GM Goodwrench crate (2 peice) motor that I want to upgrade to vortec heads. Looking for modified so I can run a high lift cam.
Problem ..... super tight on funds ..... let me know what you got....
email me rdaggett@gmail.com or PM
thank you,
Robert
Old Dec 23, 2008 | 09:34 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Looking for Vortec Heads
New GM castings 062
Heads have been upgraded with
Lt4 2.00,1.56 sodium valves
Lt4 springs,lightweight retainers
Arp 3/8 screw-in studs
Guide bosses have been machined down for clearance
machine shop bill will come with heads
950.00invested 600.00 shipped,pics are not good cell cam.
http://i104.photobucket.com/albums/m...1227162227.jpg
http://i104.photobucket.com/albums/m...1227162176.jpg
Old Dec 23, 2008 | 09:54 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
maybe you can tell me if those heads will bolt up to my tpi? i have those 12 bolt pattern tpi manifold with the center 2 bolts at 72 degrees and the others are at 90.
Old Dec 23, 2008 | 10:05 PM
Car: '88 Trans Am
Engine: 5.7L TPI
No sir they will not you will need the vortec TPI base.....
Old Dec 24, 2008 | 11:05 AM
LB87FORMULA's Avatar
Car: 87 Pontiac Formula
Engine: 5.7L Crate Engine
Transmission: 5spd NWC
I interested in the vortec heads.
Have these ever been installed and run?
Why are you selling them? i.e. damaged? etc.
Are they good for .550 lift?
Thanks,
Old Dec 24, 2008 | 11:48 AM
Car: '88 Trans Am
Engine: 5.7L TPI
these heads have never been run they are new from gm then to the machine shop. they were built for an intended street car but i went a different way with the car so the heads sat for a while i have spent a ton of cash on them and will perform as such. the valve springs are GM hot springs which are rated at 525 lift, the valves are 26.00 ea for the intake 20.00 for the ex. from gm alone. this price is 1/2 of what it cost to build.
Old Dec 30, 2008 | 06:46 PM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
Buy them new from Engine Quest, roughly $200 ea. Got mine from T & P Automotive in Texas. Don't need all the modifications to run high lift cam. Had 180 cc intake runners. Call them 210-224-0886, late afternoon or evening. Ask for Barney, he will ship them also.
Old Jan 1, 2009 | 06:25 PM
Engine: 383
Transmission: th350
I got a PM about the heads I bought so thought I'd list some features. They cc'd at between 180 and 185 on the intakes and around 73-74 on the exhausts. Came ready for screw-in studs and 1.25 or 1.44 springs, and high lift cams. Flowed at .100/.200/.300/.400/.500/.550/.600 the following 57.2/117.8/175.9/212.8/227.8/230.1/233.4 on the intake out of the box. For the exhaust 31.9/106.7/133.8/143.8/147.1/147.4/147.9. I also bought Dart Vortecs and these look and flow better. The price can't be beat. Used Summit valves for these tests 1.94/1.50. Just built a carbed 383 with the Darts and the Engine Quests will go on a TPI 383 at the end of this year.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
