Needing 350 or bigger!!!!!
Old Dec 25, 2008 | 06:49 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Hey guys tired of this stupid 305. Im tired of getting beat and i want a sbc engine but at least a 350. I want a rebuilder! Im looking for any kind but more towards a 4 bolt and a carbed engine. Im wanting one from 0-500 bucks. I want a complete engine besides the manifolds and A/C and emmisons crap. Also would like it to be around waynesville ohio!
thanks
kevin
Old Dec 25, 2008 | 08:03 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Needing 350 or bigger!!!!!
Hi,
We have a 2pc rear seal 350 with a Q-Jet manifold that is from a '92 Z-28 we bought it has the pre '87 heads and it does smoke oil I do not know if the block is 2 or 4 bolt I can check the casting number to see of if needed drop the pan. The motor ran when we pulled it in Sept. the prior owner told us it was from a mid 80's pickup It also has a Turbo 350 trans with what appears to be a B&M torque converter I have no idea what the stall speed is but the trans is avalible also it has the mount for the torque arm.
Pm me or e-mail me at daferris@cablespeed.com for photos motor is in zip code 48854
Dave
Old Dec 26, 2008 | 08:32 AM
Bump!
Old Dec 26, 2008 | 02:57 PM
kickass92z's Avatar
Car: 92 Z28/86 T/A/98 R/A T/A
Engine: 355,355,LS1
Transmission: T-56,700r4,T-56
Axle/Gears: 3:73,3:42,3:42
Check out my 383 I know you want a rebuilder but, this one is done right and I have receipts. I have around $5500 in the engine but asking $3300.00. Should be around 500hp at the crank depending on intake and carb setup...
Here is a list on the engine it is a 92 L-98 block that is the only thing used. The engine was in a 92 camaro, with a Holley Stealth ram, it requred more tuning than I wanted to do, so it literally has only been around the block 1 time.
Block was done by Tuckers Machine in Murray Ky.
Bored .030 clearenced for crank
Heads are Aluminum Patriot 2.02 1.60 valves, 64cc combustion chamber, valve springs good for up to .600 lift, angle plugs, 7/16 studs, Heads have been cnc ported, 1.6 roller rockers, hardened push rods, new roller lifters, hardened head bolts
Rotating assembly
Eagle Crank, H-beam rods, SRP coated skirt pistons, everything has been fully balanced
Cam is a Comp Cams XR276HR-12 ( e-503) Lift I believe is around .590
new Mellings oil pump
new roller timing chain
new water pump
Fabricated valve covers, notched for alternator
Engine was assembled by Mitch Leidecker at Leidecker Automotive in Ledbetter Ky. It is 9.7 compression
Old Dec 26, 2008 | 03:14 PM
88iroc52387's Avatar
I've got a 350 taken apart ready to be rebuilt (was my orignal intention. I"ll give ya everything but the serp setup for 150-300 depending on which set of heads u want i have 193 and a set of 083... The blocks a 1pc rear main, roller block (set up for roller but was a flat tappet truck motor, so no hardware), 4 bolt (don't quote me on the 4 i gotta check it might only be 2), also give ya 2 quadra (need rebuilt) and the carb manifold.... every bolt is labeled in a ziploc. I'd meet ya just outside of columbus for an extra 30 bucks if you don't wanna drive 3 1/2 hrs. If your interested PM me and I'll send you some pics and i'll look up the block number.
Old Dec 26, 2008 | 04:29 PM
Kickass92z you have the engine i want! Thats the kinda engine i am going to build but it will be over a couple months. I dont have that kinda money right now. But im sure you will sell that quick bc thats a good price but you never know what the gas is going to be like lol.
kevin
Old Dec 27, 2008 | 08:51 AM
Still looking around!
kevin
Old Dec 27, 2008 | 03:21 PM
Still looking! I know someone has one!
kevin
Old Dec 27, 2008 | 03:26 PM
kickass92z's Avatar
Engine: 355,355,LS1
Let me know if you change your mind, I would be willing to meet half way if that will help. I hate to sell the engine, but I am putting a built LS1 in my 67 camaro so I need the funds....
Old Dec 27, 2008 | 03:30 PM
If i had the money i would atleast look at it but theirs now way i can get that money right now. The most i could pull out would be like 1,200 and i dont think you want that lol ill even toss in that beast of a 305 i got lol jk.
kevin
Old Dec 28, 2008 | 10:48 PM
kickass92z's Avatar
Engine: 355,355,LS1
Wish I could help you out, but not that cheap. Good luck on your build....
Old Dec 28, 2008 | 10:58 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
buy a 2 bolt block, they are cheaper and if u really plan on makeing power then get a 2 bolt and have a machine shop splay it, it will be alot stronger then a stock 4bolt.......
Old Dec 29, 2008 | 07:24 AM
How much would that cost?
kevin
Old Dec 29, 2008 | 09:26 AM
Car: 1991 Z28 1LE
Transmission: 4l60e
kevin
depends on the machine shop, most places a cpl hundred. but even if u dont have it splayed a 2bolt block using quality arp mainstuds can withstand about 450hp just fine..........im just saying dont count out the 2 bolt blocks, alot of people just get sold on the olf 4bolt is better wich isnt always true....
Old Dec 29, 2008 | 05:21 PM
Ok i am wanting to build a motor that would be between 380-420 hp at the wheels. So willing to take 2 bolts now lol!
kevin
Old Dec 30, 2008 | 12:23 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Your not gonna find a good block , etc for what your looking to spend.
Im not trying to sound like a **** or anything but there are some good deals listed above. and The ones I offered ya also.
Your best bet if your gonna build something youself why not just call a local salvage yard and get a block from a wrecked vehicle.
Old Dec 30, 2008 | 02:25 AM
bad88_milldawg's Avatar
Car: 1991 Hardtop RS
Engine: 406 Small block
Transmission: TH 350
Axle/Gears: custom fabbed 12 bolt posi, 4:11
Id sell you my 406 small block with a serpentine setup, complete turn key engine for $1000
Old Dec 30, 2008 | 07:52 PM
Still serching!
kevin
Old Jan 6, 2009 | 12:19 AM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
there's an easy 450hp and 500 qt monster in a sbc package.
i have 3 400's and don't want to sell any.
by far the best bang for the buck.
you should get more info on this one b4 dissmissing it. IMHBO
Old Jan 6, 2009 | 11:51 PM
ya asked for a rebuilder, from 0-500 i gotta 2 bolt block, roller, plus 083 heads for 300... I'll meet ya on the outerbelt of columbus for 330 what more r ya lookin for.... Blocks never been rebuilt... take it your not interested you never got back to me through pms
Old Jan 7, 2009 | 06:50 AM
I am actually going the LT1 way guys sorry.
thanks
kevin
Old Jan 7, 2009 | 05:25 PM
Thats no problem good luck with that just make sure ya get back to people in the future when you ask them for things. I took my 4th gen out into the snow for ya to get you a whole bunch of pictures and then you stopped replying.... Just try and be conciderate to others i'm not mad or anything, i just want you to realize you may upset others if you pull that...
Old Jan 11, 2009 | 05:55 PM
lowtiderides's Avatar
Want a title? Post!
I have an 1992 z28 L98 350 Tuned port injection (TPI)
Here is a link to a video of it before it was pulled.
http://nfcruiserheads.org/forum/index.php?topic=481.0
I am asking $650 for it and it is located in North Florida. I can be reached at Al@nfcruiserheads.org as I am not on here much...
-Al
IROCZ1989
Jan 24, 2016 03:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
