Oil cooler/filter adapter studs needed
Old Jun 21, 2009 | 03:42 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I am nearing the end of a long project to build and install a 383 into my 1982 Z-28. I want to install the GM oil cooler on the engine. But I cannot find the two special studs that attach the filter adapter to the engine. Normally they are just two bolts, but on oil cooler equipped cars they are studs to keep the oil cooler in alignment and prevent it from turning and leaking. Does anyone have the two studs left over from a project or parts car? Thanks, Andy
Old Jun 21, 2009 | 05:24 PM
wbspoon's Avatar
Car: 90,94,96 C4, 93 F 07 K3500
Engine: L98, LT1
Transmission: M6
Re: Oil cooler/filter adapter studs needed
Andy if you can not find the bolts, I have a new adapter (14092135) that I will sell you for $25.00 + the shipping. If you would like to see a picture send me an email address to attach it to.
Old Jun 21, 2009 | 06:25 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Thanks, I have a new adapter, it's the special studs I need. I have actually attempted to make them myself, but that didn't work out too well. Thanks, Andy
Old Jun 21, 2009 | 07:43 PM
cam91rs1's Avatar
Suspended
Car: 91rs camaro conv
Engine: 305 tbi
Transmission: 700r4 w/shift kit
i have them 50.00 shipped
Old Jun 21, 2009 | 08:22 PM
wbspoon's Avatar
Engine: L98, LT1
Transmission: M6
The adapter that I have has the bolts. I just don't want to have the adapter without the bolts
Old Jun 22, 2009 | 01:01 PM
ANDYZ28's Avatar
Car: 1982 Z-28
There are two styles; non-oil cooler style uses bolts, and the oil cooler style uses studs which contain a boss to keep the oil cooler in alignment.
Old Jun 22, 2009 | 01:05 PM
cam91rs1's Avatar
Suspended
Engine: 305 tbi
i have the boss style one for the factory cooler
Old Jun 22, 2009 | 01:14 PM
wbspoon's Avatar
Engine: L98, LT1
Transmission: M6
Andy,
Trust me I know what you want. One reason that I ask for email addresses when I sell items is so people have an opportunity to see what I have. The bolt that you are talking about holds the oil filter adapter attachment to the block and has a pin that protrudes down into the oil cooler.
Old Jun 22, 2009 | 02:14 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Correct
Old May 11, 2016 | 03:41 PM
Darin1978's Avatar
Wbspoon,
I was reading up on alot of the articles on the Modine units. I had some remove motor for me. They are no longer available to help to the motor back in & did a poor job pulling it & separating things for me to make it eady to put the motor back in AND it appears things are missing. I have a 1987 Chevy Camaro IrocZ. Somehow pieces of the Modine cooler unit went missing. Specifically it appears im missing the center bolt that attaches, fastens everything together. I believe the unit is called KC4? My unit has a #14092135. Beyond the unit, which appears to be one piece, the 2 lines, which I have, the hollow bolt & snap ring I dont have. Is their more to this unit im missing? I hope you receive this. Thanks for any help. I can be reached at 484 239 5224. Thanks, Darin.-
Old May 12, 2016 | 06:24 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Darin, I "may" have the missing two bolts that retain it to the block.
IROCZ1989
Jan 24, 2016 03:55 PM
Navy8125
Aug 21, 2015 09:32 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
