lowering springs anyone?
Old Nov 15, 2009 | 02:03 PM
thewhitestripes's Avatar
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
anyone got a pair of lowering springs? i dont really care what brand they are an ill take em new or used. i dont wanna pay more than 150 shipped tho cause i could just get a pair off ebay for 180 brand new with free shipping
Old Nov 15, 2009 | 02:25 PM
Stephen's Avatar
Car: 87 GTA
Re: lowering springs anyone?
You can cut your stock ones for free. If they aren't work & sagginhg, they'll be good. Just don't use a torch to cut them & avoid adding excessive heat. Heat is what will ruin springs.
Old Nov 15, 2009 | 03:26 PM
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
well what should i use to cut them? like a grinder? and dont new springs stiffin the car up?
Old Nov 15, 2009 | 10:37 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
You say you need a pair? If so, do you need the front or the back. Or...do you really want a set?
Old Nov 18, 2009 | 01:52 AM
Stephen's Avatar
Car: 87 GTA
Stiffer will depend on what the spring rate is. A V6 spring is a lot softer than a WS6 spring.
To cut them, use a GOOD sawzall or better...Use a 3.5" grinder with a thin (1/8") GOOD metal cutting wheel. When I did mine, I set them in a bucket of water, with only the top few coils sticking out & cut them then. That way, the water was dispresing any heat that was introduced. Overkill? Probably. But I felt better doing it that way so.......
Old Nov 18, 2009 | 09:56 PM
ZTECH's Avatar
I have a used set of eibach springs. I am looking to get $125.00 + Shipping
Old Nov 20, 2009 | 07:34 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a set that was pulled from a 92 RS....$75+ shipping.
I don't know the make but they were coated red and I know that Jamax springs are red - ( They might be Jamax springs ). They are rusty but not damaged in any way and the replacement mounting pads are included.
If your interested - post your ZIP code for a shipping quote.
Old Aug 1, 2010 | 11:15 PM
lopezisgod's Avatar
Car: 86 iroc-z, 78 z28, 91 z28
Engine: 355-carb, 350-carb, 350-TPI
Transmission: 5speed, at, 5 speed
Axle/Gears: 3.42, 3.42-stock, 3.42-1LE
u cant getfor 180 shipped new anywhere. unless its aprivate add and the person just wants to dump them..
Old Aug 3, 2010 | 12:18 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I ahve a set of blue ones not sure of the brand would let them go for 130.00 shipped lower 38 states
Bubbajones_ya
Jul 6, 2024 08:32 PM
Lanz06
Sep 14, 2015 07:16 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
