Lt1 Parts needed
Lt1 Parts needed
I'm in the process of buildign a 94 Lt1 383 stroker.. anyone have parts such as ...
roller rockers 1.6
springs
lifters
58mm body
crank
6" rods
pistions
big cam
36lb injectors
complete heads
fuel pressure regulator
roller rockers 1.6
springs
lifters
58mm body
crank
6" rods
pistions
big cam
36lb injectors
complete heads
Re: Lt1 Parts needed
Ive got some 1.5 RR's, a HUGE cam (dur 234/234 lift 618/618), and SLP LT1 AFPR
How much are you looking to spend?
I also have a LT1 swap harness FS if you want to clean up the wiring
damn i was looking for 1.6 RR's, how much for the rockers? .. i just bought a harness, that cam is huge damn to big i wouldnt be able to daily drive, i was looking for something like .594 lift 112 , how much for the SLP ? can i get pics?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'll have a set of stock LT1 springs, caps, & keepers from a 95 in the very near future. If your interested just post and offer and your Zip code so I can use it to get a shipping quote for Ya'.
That's what I figured but wanted to post anyway to be sure. I am going with LT4 springs on my LT1....... probably a good idea for your build as well !
www.southbayfuelinjectors.com
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
I have a torn apart LT1. I have pistons with 120k miles no them, full tpi, and stock cam. I also have like new roller lifters. They have 20k on them, they were recently changed before I tore the engine down.I have almost the full engine except heads and distributor. Everything is for sale. Just ask if you want anything. I can give prices depending on what parts you want. Send me a private message if you are interested. I check my messages more often then my posts.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I have brand new parts for your 383 LT1 build if interested. I purchased a complete new LT1 383 build then tore it down for a supercharger setup so all NEW parts are for sale:
New Speed Pro Forged & Skirted Pistons (11:1 compression) $300
New Speed Pro 1/16 Moly Rings - Hand Fit To Cylinders $80
New Eagle Cast Steel Crank 3.75 Stroke $170
New Eagle 5.7 Rods W/Floating Pins $300
New Comp-Cams LT1 Cam (.576/.571 lift @ .050, 230/236 duration) 113 LSA $200 Comp cams recommends bee hive springs P/N 26918
New Steel L98/LT1 Flywheel $350
New LT1 accessory brackets $100
New A/C delete pulley $40
Used Factory Push Rods free with any rotating assembly purchase
Let me know if interested.
